someone help with clearance issue - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 03-13-2012, 09:47 PM   #1
Default someone help with clearance issue
i am putting a stock ls1 motor together and i just bought some ls6 317 casting prc heads that are 66cc and shaved 30 thousands i am wanting to go with the f14 highlift cam. should there be any clearance issuue's with this setup.
chrisrhino is offline   Reply With Quote
Old 03-14-2012, 07:10 AM   #2
are you joking this is not advanced tech and your planning to clay the engine right ?
BigRich954RR is offline   Reply With Quote
Old 03-14-2012, 04:24 PM   #3
Old Geezer's Avatar
Thumbs down Seems like
Quote:
This forum is a dumping ground for every "engine 101" ?? in the book....
Old Geezer is offline   Reply With Quote
Old 03-28-2012, 09:33 AM   #4
Did you take an additional .030 off or is that what they came with? I have those heads with their V3 cam which is similar to the F14 and have not had a clearance problem. However I would run the Stock gaskets since they are a little taller and not the Cometic ones.
techls1 is offline   Reply With Quote
Old 04-05-2012, 01:22 AM   #5
Ethan[ws6]'s Avatar
clay it. only way to know for sure. standard clearance specs for PTV: Intake .080" Exhaust .100"
Ethan[ws6] is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
325 deck clearance Bobby355 Generation III Internal Engine 5 12-16-2016 10:46 AM
Iron block LS3 piston clearance? nobreaks254 Generation IV Internal Engine 3 08-09-2012 08:08 AM
oil pickup clearance abadbowtie Conversions & Hybrids 5 03-05-2012 01:03 PM
BMR Box VS Tube.. 01ls1lover Suspension & Brakes 8 03-15-2008 07:43 AM
piston to head clearance ChucksZ06 Generation IV Internal Engine 4 12-19-2005 01:54 AM
Tags
clearance, ground, trans, ws6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
