What kinda converter and shift kit do I need for my 4L60E - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 10-05-2015, 03:24 PM   #1
Default What kinda converter and shift kit do I need for my 4L60E
Hey, I'm doing a 5.3 swap in a Gbody and I'm installing a Holley Mid-Rise intake with a 90mm throttle body and 30lbs injectors on my 5.3 engine. Also I'm going posi track with 3:73 gears in the rear end. I just have no clue as to what I should do with the tranny. This is a weekend driver.
Colemanj9483 is offline   Reply With Quote
Old 10-11-2015, 11:12 AM   #2
I used a transgo shift kit... And a tci 3000 converter.
ski7541 is offline   Reply With Quote
Old 10-11-2015, 05:12 PM   #3
Kool I'm thinking about adding a turbocharger later on
Old 01-02-2016, 01:28 PM   #4
X2 - TransGo works very well.
With the turbo you may need to add some hard parts or it will give up.
The choice of converter stall depends on:
1. idle quality required (stall too low - it dies when you drop it in drive)
2. how hot is the cam?
3. are you traction limited?
3,000 stall will definitely feel good, but may be un-driveable in the rain, and slow up your 60 foot time (with street tires and suspension tune).
Are you going to keep converter lock-up? A converter that will stay locked with 500 ft. lbs. is $$$.
panic is offline   Reply With Quote
Old 01-11-2016, 06:42 PM   #5
Old Geezer's Avatar
Advanced engineering ? ..........
Old Geezer is offline   Reply With Quote
Old 04-28-2016, 06:11 AM   #6
Seems like it's time to shut this section down. Every post here is in the wrong place lol. None of it is advanced....anything.
midnightbluS10 is offline   Reply With Quote
Old 07-01-2016, 07:42 AM   #7
MaroonMonsterLS1's Avatar
Go to the transmission section and do a quick search. This is a "dead horse" subject.
But i'll still try to help instead of just redirecting.
A common list is the transgo HD2 shift kit, a sonnax .500 boost valve, corvette servo, drill separator plate 3-4 feed hole to .100. That's the common stuff
Converter decision is going to depend on your preferance. I'd recommend 3200 for spirited stoplight drags and daily driver capability.
MaroonMonsterLS1 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
02 silverado Augustin90 New LS1 Owners - Newbie Tech 0 12-27-2016 11:33 AM
5.3 turbo build questions. Need some input!! Fier23 Generation III Internal Engine 11 01-19-2016 09:21 PM
5.3 donor vehicle what do I keep parrisw Conversions & Hybrids 2 11-10-2015 12:44 PM
5.3 into a 98 2500 98SMGWS6 Conversions & Hybrids 3 03-29-2015 08:36 PM
aluminum 5.3 info Tig Conversions & Hybrids 39 02-17-2011 01:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
