Advanced Engineering Tech For the more hardcore LS1TECH residents
Bare block build for 2nd gen swap
Old 07-26-2016, 06:45 AM
76firechicken's Avatar
Default Bare block build for 2nd gen swap
I may have access to an iron 5.3 that could use a rebuild, or I could buy a bare 6.0 block to start a build. In the opinion of the experts, which would be more cost effective for a 5-600 hp build if I'm starting with just a block?
Build will be efi and I'm undecided on if I want to boost it yet.
Old 07-26-2016, 03:19 PM
KCS
Moderator
KCS's Avatar
Depends if you boost it or not. The 5.3L would probably be best choice for boost, or the 6.0L of you stay NA or nitrous.
Old 07-27-2016, 06:52 AM
That was about what I had assumed. I suppose I need to weigh my options as far as what will help me reach my goals better. I'd like to make 500/500 at the wheels reliably and comfortably because I plan on driving the car a lot.
Quick Reply: Bare block build for 2nd gen swap
