Advanced Engineering Tech For the more hardcore LS1TECH residents
LSX TALLDECK Need Info
Old 05-23-2016, 07:36 PM
Byryd's Avatar
Default LSX TALLDECK Need Info
I found a talldeck LSX block with part number 19212323 on it, but I cannot find anything on the internet about it. Is this a good block or one to stay away from?
Old 05-24-2016, 01:16 PM
Fraser588's Avatar
Its a good block, heavy.
Only down side to the tall deck LSX, has a factory cam position, so you're limited on stroke size. Need spacers for your intake and maybe for your oil pan, 4.375" stroke hits the GTO oil pan, may hit others. Not many use a factory pan with this block.
Its a good block that would allow you to use a heavy thick piston for Nitrous/FI but I don't think i'd use this for an NA motor.
Old 05-24-2016, 05:51 PM
Byryd's Avatar
Thank You
Old 05-29-2016, 01:18 PM
helicoil's Avatar
Over 4.250 will require some work in the clearancing department. Small rod journal and/or cam base circle.
I have done 4.250" in a tall deck std. cam location with the right 2.100" rods several times. Works great, nice combo for 454 inches with a N20 piston built right.
That is a sound block.
Quick Reply: LSX TALLDECK Need Info
