4th gen aerodynamics - Page 3 - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 12-15-2016, 06:08 PM   #41
HioSSilver's Avatar
I got to thinking.....i figured i would post a little more eye of a few things i have made.
Restrictor cone i make for cars running restricto class.
E46 roof
Bmw airbox . I made all of it except for the trumpet area. There is even a filter channel inside i made.
Bmw 4.0 v8 airbox before
After
One of the more neat projects i did was a guy brought me a carbon pin on hood but he wanted it on hinges........sssssoooo
Pic of it in the vacuum bag
And finished
HioSSilver is offline   Reply With Quote
Old 12-15-2016, 08:22 PM   #42
Very nice work Hio. I am going to start working with fiberglass since I would like to make some parts for my Camaro. I just finished my first year of working on an IMSA team and all the aero work inspired me to shore up some of the many deficiencies on our cars. Are you still working in racing?
zrated383 is offline   Reply With Quote
Old 12-15-2016, 08:34 PM   #43
Excellent stuff as usual from hio.
79_T/A is offline   Reply With Quote
Old 12-15-2016, 11:12 PM   #44
HioSSilver's Avatar
Thanks guys....i wish i had pics of all my stuff but alot of it happened before pic phones/storage got good. I've made m I re complicated stuff like entry and exit ducts for the radiator to.
No i don't work in racing anymore. I work out if a shop at my house. Once in a while i get some race cars here to work on.p
http://s143.photobucket.com/user/Hio...port%20v8%20m3
There is a vid of it somewhere after we got it fixed up.
Old 01-10-2017, 09:43 PM   #45
HioSSilver's Avatar
Alright guys. I have the intake/cai I've been working on molded and a part made.
Old 01-11-2017, 06:35 AM   #46
Project_Reaper's Avatar
Your an inspiration as always HIO, great looking piece
Project_Reaper is offline   Reply With Quote
Old 01-11-2017, 07:05 AM   #47
autogeek23's Avatar
this is badass. would love to improve the aero of my trans am.
autogeek23 is offline   Reply With Quote
Old 01-11-2017, 09:34 AM   #48
Well done as usual. How do you seal the two shells together? Planning on any sort of air filtration for that mammoth?
imma_stocker is offline   Reply With Quote
Old 01-11-2017, 09:51 AM   #49
HioSSilver's Avatar
Thanks guys.
The 2 shells are held together with 3 layers of carbon. Another way i could do it is leave a small flange around the shells from molding them and just use a good epoxy.
Air filtration is a oe sized filter. Could be done a couple different ways.
1- just make a simple frame to hold the filter to the cai.
2- a box holding the filter and mounted to the car and fed through the bumber. That's the route I'm goin to hopefully achieved some ram air effect.
2.a - the box could be fed several ways via hoses off fog light holes or whatever else one could figure out.
Old 01-11-2017, 10:53 AM   #50
Darth_V8r's Avatar
Quote:
Originally Posted by HioSSilver View Post
Thanks guys.
Sweet looking intake for sure! you thinking to come out the license plate spot? i've seen others post that's where the air pressure is highest?
Darth_V8r is online now   Reply With Quote
Old 01-11-2017, 11:23 AM   #51
Very cool video of a 4th gen in the wind tunnel.
Chrisingermany is offline   Reply With Quote
Old 01-11-2017, 11:34 AM   #52
Mike Morris's Avatar
Looks great Hio. Will clear an SS hood?
Mike Morris is offline   Reply With Quote
Old 01-11-2017, 11:43 AM   #53
98_WS6_M6's Avatar
That's what I'm going to do with it once Hio makes a second one
98_WS6_M6 is offline   Reply With Quote
Old 01-11-2017, 11:45 AM   #54
HioSSilver's Avatar
Quote:
License plate area is the areai will likely put it. About anywhere on the front should be fine .
Quote:
https://youtu.be/DAVoAJ4ftB0
Good find! Never seen that before.
Quote:
It should clear all hoods if the latch area is cut out i think.
Old 01-11-2017, 11:53 AM   #55
Interesting, that wind tunnel video the car didn't have headlights lol Or it had covers.
smitty2919 is offline   Reply With Quote
Old 01-13-2017, 08:46 AM   #56
z28241's Avatar
Would love to see a wind tunnel vid like that with a 98-02 WS6..
Hio- good stuff! looks like time well spent!
z28241 is offline   Reply With Quote
Old 01-13-2017, 03:54 PM   #57
Quote:
That car is setup for high speed events. Headlights have sealed covers from hood to bumper. Rear diffuser actually works. NOT the SS spoiler, more like the 6LE, Dick Harrell, or RK Sport spoiler. RK makes a few but only 1 actually works.
Found that video a long time ago and watched it probably 20x back to back.
Old 01-19-2017, 12:47 PM   #58
Ive recently just finished the book Race car aerodynamics by Katts, (Very good read by the way) and based on the information Ive gathered from there, the subject of the rear deck and spoiler design on our 4th gens looks to have been designed more in an effort to reduce overall drag *hence the way the trunk lid rounds off with a similar degree angle of the rear glass* with a minor effort to alleviate lift with the flat wing that is level with the trunk lid. Now I have an aftermarket lip spoiler which helps to further reduce lift but also comes at a small increase in drag, but if we were to fill in that dropping area below the spoiler the possible outcome should show a moderate increase in negative lift, possibly even positive down-force (depending on if there are any front mods for down-force acting to shift center force further to the front) with an equal increase in drag due to the now larger separation bubble at the back now that there is not a small amount of air flow going under the wing to help move some of the high pressure air around the rear bumper. From what Ive researched the best possible outcome to decrease lift and also try to decrease our drag would be to invest in a properly designed flat floor with channels starting just before or right at the rear axles with a degree slope of around 6-10, this will move the air under the car faster causing a lower pressure area which of course reduces lift and also accelerates the air coming out of the back of the car with a diffuser ( also note the air would be coming up closer to the taillights due to the high rake of the diffuser which reduces the size of the flow separation bubble) and in doing so this reduction in the separation bubble reduces overall drag, the flat bottom and diffuser reduces lift. Also the aspect of using the exhaust within the venturi tunnels can accelerate this effect under throttle for more down-force and slightly smaller separation bubble at the back, possibly even routing the exhaust to exit between the taillights theoretically could nearly completely dissipate the rear separation bubble increasing negative lift and lowering your drag even further. depending on how aggressive your down-force setup is (in most cases as down-force increases so does drag) your Cd could be as low as .31-.33 with lift numbers near 0.1...of course this is all speculation and lower drag coefficients could be had with the sacrifice of negative lift.
Old 01-19-2017, 03:19 PM   #59
DIY aero testing how to:
Cut an entire ball of yarn into 8" sections.
Secure those sections of yarn all over the body, especially areas you are modifying.
Have a friend with camera (two friends really, one to drive and one to film) follow you down the road at various mph.
Watch the yarn to see which way air is moving.
Old 01-19-2017, 03:28 PM   #60
HioSSilver's Avatar
We've used the yarn idea before!
It's pretty easy to make down force. Reducing drag is whats tough.
Related Topics
Thread Thread Starter Forum Replies Last Post
Flat black SS hood and spoiler? DutchmanZ Paint & Body Work 20 01-08-2010 06:48 PM
Revealed for GM's 100th Anniversary - Chevrolet Volt TriShield Automotive News, Media & Press 53 11-21-2008 02:30 PM
Aerodynamics - an explanation 300bhp/ton Road Racing 4 08-26-2005 02:21 PM
Tuners: Carlsson's 480hp SLK55 Shinkaze Automotive News, Media & Press 0 08-07-2004 07:37 PM
440 HP Mustang GT-R concept Shinkaze Automotive News, Media & Press 24 04-11-2004 11:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
