MAX RPM LS-X Engine 10500 + RPM - Page 3 - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 03-02-2017, 10:21 AM   #41
LS1Tech Sponsor
Default Dart Block @ 8.8
Hi All, I spoke to Richard and found that he has a LS Billet Block with 8.8" deck.
He stated no problem with removal of lifter/cam bores.
He stated that his oil system would work fine for this case.
The block problem of dealing with the Deck Height availability MUST demand a longer stroke.
This will lower maximum RPM to 12K ?
Lance
Pantera EFI is offline   Reply With Quote
Old 03-02-2017, 11:09 AM   #42
LS1Tech Sponsor
Martin Smallwood's Avatar
Here is what I would do then:
3.150" stroke
6.200" rod
1.025" CH piston
This would leave the piston zero decked with a 8.8" deck height and give you 327 cubic inches. With the 6.200" rod and 3.150" stroke you're still pretty close to 2:1 rod to stroke ratio (1.96:1 actual) which is what I would want for such a high RPM engine.
If the piston manufacturer thinks that a 1.025" CH will make the piston too weak, I would back the rod length down to 6.150". This would give you a 1.075" CH which in my opinion should be perfectly fine and still gives you a 1.95:1 rod to stroke ratio.
Martin Smallwood is online now   Reply With Quote
Old 03-21-2017, 09:37 AM   #43
1CAMWNDR's Avatar
Pantera EFI have you had any way to test your head design with respect to how the barrel valve operation and timing will affect desired intake and exhaust port and manifold runner length?
Does it still have similar characteristics as poppet valve timing-throttle bodies-cam timing have on desired port and runner length?
Will the ports in this head be in same or similar location as current heads? Or might they be raised for a more straight shot into the combustion chamber?
1CAMWNDR is offline   Reply With Quote
Old 03-23-2017, 10:49 AM   #44
LS1Tech Sponsor
Default Port Location = LS 1,2,3,7
Hi, yes a good remark, the port locations will remain the same for the exhaust.
A low hood requirement will also be important for the Intake Trumpets.
The most common port location will use the common manifolds if desired, just NO air Door.
The EAP model I use allows for runner length at MAX RPM.
That can be used for 1/2 wave tuning to predict the second torque peak RPM.
I understand your "straight shot" desire, to understand that task you would need to see my head design.
I could e-mail some pics ?
Lance
Old 03-23-2017, 02:03 PM   #45
1CAMWNDR's Avatar
Lance
I see. As long as the different valve style will not alter pressure wave characteristics...or has been taken into account in the design of the intake runner and head ports.
No need to send pics, I was just curious. I bet you could even make a Hemi style head with the "valve" location rotated 90 .
Old 03-25-2017, 10:52 AM   #46
LS1Tech Sponsor
Default KHI Head
Hi, yes sure.
I made a head, KHI 250cc, with the Intake Port over the piston top AND the TWO exhaust ports on either side, a four valve head tested by Jerry Branch.
He stated that head flowed better than ALL OTHERS for the same Valve Size.
This "bike" is running to this day.
Lance
Related Topics
Thread Thread Starter Forum Replies Last Post
Lean at WOT above 5k 240-Lsx PCM Diagnostics & Tuning 8 08-17-2015 12:28 PM
Bench harness and LS1 edit unlimited Simpson Speed PCM Diagnostics & Tuning 16 01-11-2013 11:17 PM
[VIDEO] External Engine Video How-To Thread LsxMovie Generation III External Engine 0 01-11-2011 12:21 AM
Where we are at with the PatriotDream.org Camaro 4Birdman Racer's Lounge 114 07-09-2010 03:33 PM
LS1 TECH - LETS HELP OUR FELLOW AMERICANS AFFECTED BY HURRICANE KATRINA Diolar Magnum Racer's Lounge 54 10-09-2005 07:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
