Updated Valve event / DCR / SCR / Header length spreadsheet - Page 2 - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 05-19-2006, 03:51 PM   #21
No Juice's Avatar
Quote:
Originally Posted by matts22
Great stuff guys...
I did notice a problem though. When you go under the tab "Compare DCR" there is no formula in cells B42 and G42, clearance volume. This should be the same as in B42 of the "DCR" tab, which is =SUM(0.7853982*(B17^2)*B21) (and for the G column, just substitute G for B in that formula.
If this isn't fixed, it will throw off the SCR and DCR values in this tab.
Also found that ICA uses column B as well. Should be G
What are we looking for when comparing cams using the same heads. I know we want a DCR close to 8.5, but what else?
No Juice is offline   Reply With Quote
Old 05-22-2006, 06:33 AM   #22
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Fixed the two issues above. If you find anything else, or want to see stuff added, let me know.
J-Rod is offline   Reply With Quote
Old 05-22-2006, 07:47 PM   #23
joecar's Avatar
Good work, thanks for the effort.
Comment: the "Piston Speed" is actually "Mean Piston Speed".
joecar is offline   Reply With Quote
Old 06-25-2006, 01:47 AM   #24
Do you have to have Excell to run this?
Spellbound is offline   Reply With Quote
Old 07-20-2006, 03:31 PM   #25
Moderator
davered00ss's Avatar
Will not work for me.
davered00ss is offline   Reply With Quote
Old 07-21-2006, 01:08 PM   #26
J-Rod's Avatar
What doesn't work. You can't download it, or what?
Old 07-31-2006, 08:23 PM   #27
Hi J-Rod.
This did everything I wanted some months back, so maybe I'm just looking for something different now. All I want is to look at various DCRs vs. SCR and IVC. All that the speadsheet should need is stroke, rod length, SCR and IVC @ 0.006", 0.050" or 0.200" to do this. How do I skip over the other couple of dozen specs? For example, do I have to 'invent' an intake cam duration and ICL to get the desired IVC to appear in the box, or...? Ditto how/where can I enter the SCR I want to use without having to create it from a handfull of volumes plus the engine bore & stroke?
Thanks.
-MB
MadBill is offline   Reply With Quote
Old 10-27-2006, 04:59 PM   #28
The stunningman's Avatar
Quote:
Ditto I can't get it to open It sends me to another D/L board(?) where I can't figure out what to do.
The stunningman is offline   Reply With Quote
Old 11-02-2006, 10:11 PM   #29
Keenov's Avatar
Quote:
Try to just right click and save as. Works fine here.
Keenov is offline   Reply With Quote
Old 11-30-2006, 06:23 AM   #30
UNDER PRESSURE MOD
The Alchemist's Avatar
Is the server down? I tried to right click and save and I get an error about the server being down or unrecognized.
I'm trying to calculate my dcr and scr change from going from a stock 0.056" gasket to a 0.040" gasket.
Thanks.
The Alchemist is offline   Reply With Quote
Old 12-17-2006, 04:14 PM   #31
fast98's Avatar
i have been noticing theres a problem with the calculation of scr, and if you look under head gasket volume thats where the problem is its way lower than it should be, so i clicked on it and it says inconsistent formula.
fast98 is offline   Reply With Quote
Old 12-18-2006, 12:35 AM   #32
J-Rod's Avatar
Sorry, EV1 is no longer hosting. So, i need to move it. I'll look at the SCR while I'm at it...
Old 01-22-2007, 11:12 PM   #33
cowboysfan's Avatar
wil this be up any time soon. clicked on it and said "BAD GATEWAY".
fuerzaws6
cowboysfan is offline   Reply With Quote
Old 01-23-2007, 09:49 AM   #34
J-Rod's Avatar
Until I can get a new site to host it on use this one... I am uploading it in .zip format.
Old 05-01-2007, 12:03 PM   #35
SideStep's Avatar
Let me make sure I using this spreadsheet correctly:
If my pistons are .007 above the deck of the block (sticking out) I enter that as -.007 in the spreadsheet, Right??? Not as a positive value, because you are calculating how much of the gasket/chamber volume the piston is taking up...???
For example: ( the below would should pistons sticking-out of the block by .007)
Bore______________________________________4
ST = Stroke_______________________________3.622
RL = Rod Length____________________________6.098
Number of cylinders_________________________8
Deck Height_______________________________-0.007
Piston Dome or Dish (- for a dome + for a dish)__0
Compressed Head gasket thickness____________0.06
Cylinder Head Chamber Volume________________64
SideStep is offline   Reply With Quote
Old 05-06-2007, 06:12 PM   #36
slowride's Avatar
Yes, Just think of it in the same way as the piston dish/dome.
slowride is offline   Reply With Quote
Old 05-31-2007, 07:58 PM   #37
Gannet's Avatar
Is there any reason the sheet does not consider top ring volume? Or is that hidden somewhere I haven't seen it?
Adding it to my version of the sheet, I get a stock SCR for an LS-1 of 10.13 as opposed to 10.31 without it. That's assuming a top ring down distance of 0.250", which seemed a reasonable number. I don't have the actual stock dimension, does anyone?
Gannet is offline   Reply With Quote
Old 06-09-2007, 09:11 AM   #38
slowride's Avatar
I take it was omitted as to error in the direction of safety. I would think over time a little carbon is going to build up somewhere in the chamber increasing compression ever so slightly. So having a little cushion is fine with me.
Old 08-13-2007, 10:33 PM   #39
This spreadsheet gives out fairly high dynamic compression numbers... A stock LS1 with the 230+ degree duration cam gives me very close to 8.5:1 dynamic. Correct me if I am wrong but that is a said "limit" for pump gas, which would not make sense with a cam that big on a stock SCR LS1.
SySt666 is offline   Reply With Quote
Old 09-07-2007, 01:02 PM   #40
LS1 Tech Administrator
Patrick G's Avatar
Quote:
You must not be entering the correct duration at .006" for the 230 @ .050" cam. Most aggressive LS1 cam 230 lobes have between 279-282 degrees duration at .006". Are you using numbers in that range at .006"?
Patrick G is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
DCR calculation question Darth_V8r Generation III Internal Engine 16 05-22-2015 10:14 AM
Math to figure out if your car will run on pump gas. J-Rod Advanced Engineering Tech 23 01-11-2011 04:45 PM
DCR to SCR to VE from stock to MOD 1SLwLS1 Advanced Engineering Tech 3 03-31-2010 01:34 PM
IVC calculation haacer LT1-LT4 Modifications 2 07-14-2009 04:00 PM
Is DCR a Back Door Approach to Power/Torque Optimization Steve Bryant Advanced Engineering Tech 11 05-27-2008 11:45 PM
Tags
bogart, calculations, calculator, calulator, cam, camshaft, d10, dcr, event, events, fbody, som, spreadsheet, timing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
