For those who want big nasty cams with lots of lift, etc... - Page 2 - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 10-02-2003, 06:00 PM   #21
jfm
Moderator
jfm's Avatar
Default Re: For those who want big nasty cams with lots of lift, etc...
Will the Ti valves beat the seats up faster due to their hardness?
jfm is offline   Reply With Quote
Old 10-03-2003, 08:23 AM   #22
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
No, in fact for Ti valves it is best to use a BeC valve seat. They shed heat better, and they take abuse better than a steel seat.
J-Rod is offline   Reply With Quote
Old 10-03-2003, 09:28 AM   #23
Quote:
Thats my whole deal, I think you can use a stock lifter, and a 918 with any of the cams currently out (even the really big ones) if the rest of the valvetrain is light enough. Say a Ti retainer, and either a NaK filled steel valve or a Ti valve...
That seems to me to be true by definition. The question is whether the rest of the valve train can be made light enough and whether one can afford it.
critter is offline   Reply With Quote
Old 10-03-2003, 09:44 AM   #24
Absolutely dead nuts spot-on.
Now, here's the question, and folks like Comp better know the answer, and I would appreciate them publicizing it for once and for all.
What, SPECIFICALLY, is that valvetrain mass?
PS - this is exactly how GM designs springs.
PacerX is offline   Reply With Quote
Old 10-03-2003, 11:50 AM   #25
restoman45's Avatar
very informitive post j-rod, thanks for all that info...very interesting reading material
restoman45 is offline   Reply With Quote
Old 10-03-2003, 03:56 PM   #26
Boosted LS1's Avatar
J-Rod, heck of a post, top man! I've printed it for future reference.
Boosted LS1 is offline   Reply With Quote
Old 10-17-2005, 12:08 PM   #27
LS1Tech Co-Founder
Nine Ball's Avatar
TTT for new forum
Nine Ball is offline   Reply With Quote
Old 10-17-2005, 10:26 PM   #28
SStrokerAce is offline   Reply With Quote
Old 10-18-2005, 01:22 AM   #29
ArcticZ28's Avatar
Has anyone found affordable Ti/NaK valves since then? I know the market value for those has to have dropped at least a bit. Or maybe, has anyone found a lighter and more affordable valvetrain combo that has worked well for them? If so, what was the combo, from cam specs to the type of retainers used?
ArcticZ28 is offline   Reply With Quote
Old 10-18-2005, 02:00 AM   #30
Var
Since ti prices have gone up, they might be even more now.
Var is offline   Reply With Quote
Old 10-18-2005, 09:12 AM   #31
1fastWS6's Avatar
Good info....you should note the first part of that is a quote from David Reher of Reher-Morrison.
1fastWS6 is offline   Reply With Quote
Old 10-18-2005, 10:25 AM   #32
TAQuickness's Avatar
Quote:
Originally Posted by PacerX
There are a few things I really wish for in this life:
First being a properly designed spring, spec'd out to the point of...
a. Maximum valvetrain mass
b. Maximum rpm for a given valvetrain mass
c. Most aggressive lobe profile possible
d. Maximum lift
Then you could have a (fairly) simple chart...
If your valvetrain weighs "x", then the maximum lift becomes "y", your max reliable rpm becomes "z" using lobe profile "a" at lift "b".
This is the type of issue that bothers the hell out of me. If ANYONE actually did their homework while designing springs, they HAD TO go through this process.
Otherwise, they're just shooting in the dark.
Sadly, most of the aftermarket shoots in the dark.
Just like pushrods. There ought to be a dmaned chart out there that says:
Deck the head .010, go to a .020 smaller base circle cam, with stock lifters and stock thickness gaskets and "Brand "x" rockers and your correct pushrod length is "y".
Holy hell. Somebody get GM to give me the CAD model and I'll calculate it out.
I'd like to see something like this
TAQuickness is offline   Reply With Quote
Old 11-05-2005, 01:16 PM   #33
ShevrolayZ28's Avatar
What a great thread. I found it during my quest to learn which cams would deliver the kind of performance gains I want while maintaining reasonable valve train stability/dynamics/geometry. IE I want good "steetable" performance and low wear.
I see there's much more to it than just picking the right cam.
To do it right, I guess I'd be looking at using light weight valves, harder valve seats, strong valve springs with quality retaining hardware, and maybe even better lifters.
But since my desire is not to have an insane high RPM drag car, like most of you madmen lol, I may not need all the stuff I listed above. Nevertheless, excellent info in this thread.
Props!!!
...back to lurking and learning about cams. ....hmmm ramp rates, durations, lift, lsa
ShevrolayZ28 is offline   Reply With Quote
Old 11-05-2005, 01:36 PM   #34
treyZ28's Avatar
excellent read. i'll have to go back and re-read it as i skimmed through it. A lot of it was myth I always questioned.
One thing I'm glad to hear is that the mass/spring/damper systems I studied in differential equations is true! In reading your write up, I flashed back to diff eq. mY'' + dY' + KY = F(t). sweet.
One question: consrvation of every. Takes energy (gas) to compress the spring. where does it go when its decompressing?
For example, losses to compress a mixture in a cylinder are typicaly not taken into the pumping loss concideration because aside from the heat loss- it is regained durring expansion. Whats going on with this spring. I like convervation laws, they make things easy. Cancel out = good.
treyZ28 is offline   Reply With Quote
Old 11-05-2005, 01:47 PM   #35
treyZ28's Avatar
On a side and somewhat related note:
I've noticed a terrible tendancy for people to make poor camshaft selections.
Old 11-05-2005, 02:06 PM   #36
Yes. And I see a good number of lifter problems popping up lately for guys with high ramp rate cams (most of the latest and greatest performing cams).
And your differential calculus? Don't go there! The sping and dash pot problems...yuck!
Old 11-06-2005, 04:24 PM   #37
TAF Motorsports's Avatar
Ferrea makes hollow stem valves for the LSx
http://www.ferrea.com/catalog/2004Domestic.pdf
Page 26. I got a quote from a LS1tech vendor for $32 a piece.
TAF Motorsports is offline   Reply With Quote
Old 11-06-2005, 09:41 PM   #38
ArcticZ28's Avatar
Anyone have experience with them, especially with high duration/lift cams (such as 24x/24x and low .6xx lifts) and dual springs?
Old 11-07-2005, 07:09 PM   #39
When does lift enter into the picture? My cam has .608/.612 lift using XER lobes. I'm running Ferrea dual valve springs with stock lifters and spin it up to 7K. It has ferrea 2.055/1.575 valves.
From what I've read, the 918s don't have enough seat pressure or can handle the lift.
04Yukonxl is offline   Reply With Quote
Old 11-07-2005, 07:27 PM   #40
Just to educate me, on what basis did you make this comment? What do you consider to be a poor camshaft selection?
Related Topics
Thread Thread Starter Forum Replies Last Post
Brand New PAC-1218 Valve Springs (set of 16) erikthegoalie Parts Classifieds 9 03-10-2017 05:21 AM
Review: Comp Cams New Conical Valvesprings for LS Engines KCS Generation III Internal Engine 41 02-17-2017 11:31 AM
PAC 1518's or Duals?? SOMbitch Generation III Internal Engine 24 01-04-2017 05:46 PM
PSI Valve Spring Kit ls1king000 Parts Classifieds 0 02-05-2016 09:45 PM
F/S New in the box PAC 1218 Beehive Valve Springs doww301 Parts Classifieds 2 01-04-2016 12:24 AM
Tags
555, 7000rpm, adjusting, beehive, big, hydraulic, ivo, lotscom, lsa, morrison, optron, powered, reher, roller, spintron, valves, vbulletin, xe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
