Help choosing valve events - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 10-25-2006, 05:07 PM   #1
Gannet's Avatar
Default Help choosing valve events
I'm hoping some of the resident experts could help me choose valve events. I'm trying to select a cam that way, rather than the more "traditional" way. I think if we work through the exercise on one pretty typical car, the methodology should be applicable to other combinations.
The parameters:
'02 Corvette LS-1, longtubes, hi-flow cats, CAI, otherwise stock. Pretty common case.
Stock, unopened shortblock.
Looking for peak torque around 4800, peak HP around 6300, shift at 6500.
Within that, idle quality is not important, and a broad power band is desired. Would also like to boost the low stock DCR if possible in the hopes of both better power and better mileage.
Comments from the experts as to what valve event timings might make sense? At .006, .050, .200, whatever you think is most appropriate.
Gannet is offline   Reply With Quote
Old 10-27-2006, 05:12 PM   #2
Gannet's Avatar
Anybody? Or was this a stupid question?
Old 10-27-2006, 05:32 PM   #3
It's not a stupid question; it's a very advanced and open question.
There aren't many here that can answer that sort of question, and those that
can are likely not going to divulge their methods.
Having said that, there a many off-the-shelf cams that will give you the
criteria you list. You are probably better off searching for members with
similar setups and asking which cam grind they are using.
Adrenaline_Z is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Help me understand Valve Events ? squalor Generation III Internal Engine 37 05-04-2015 09:28 AM
Decide on Heads or Cam First? egott_91 Generation III Internal Engine 22 03-04-2012 06:46 PM
how to pick proper valve events - Cam Experts please come in skorpion317 Generation III Internal Engine 6 08-23-2010 12:24 PM
Camshaft for restricted RPM range stumprrp Advanced Engineering Tech 2 01-02-2010 06:49 PM
Camshaft Discussion part II J-Rod Generation III Internal Engine 408 10-08-2004 10:57 PM
Tags
427, choose, events, lsx, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
