Advanced Engineering Tech For the more hardcore LS1TECH residents
Can you over throttlebody a efi motor
Old 12-29-2006, 01:10 AM
ls1408cp's Avatar
Default Can you over throttlebody a efi motor
Can you over throttlebody a efi motor? I sometimes hear you cant but wanted to hear what others thought.
Old 12-29-2006, 01:16 AM
JohnnyC's Avatar
More information please... what exactly are you trying to determine? Be more specific.
Old 12-29-2006, 01:25 AM
ls1408cp's Avatar
not much more to tell would a 2600cfm throttle body hurt my car?
Old 12-29-2006, 01:33 AM
ls1408cp's Avatar
you dont need my specs to answer this
Old 12-29-2006, 03:11 AM
ringram's Avatar
Generally no, but you do need to make sure your manifold has the correct runner configuration to suit the engine application.
Old 12-29-2006, 04:46 AM
Bink's Avatar
....and that the suggested TB provides adequate "sensitivity" at low airflow. Otherwise idle tuning will be hell on earth
Old 12-29-2006, 04:51 AM
ls1408cp's Avatar
I am going to disconnect my IAC sensor and adjust idle like a carb one setting.
Old 12-29-2006, 09:24 AM
SStrokerAce's Avatar
please don't disconnect the IAC....
The general answer to this question is NO, you can't over throttle body a motor in terms of HP output. I would imagine that you could get to a level where you could, like you can over plenum a motor, but EFI usually kills the issues with transitional response.... so just thinking outloud I don't see that as a problem either.
Bret
Old 12-29-2006, 02:03 PM
ls1408cp's Avatar
why shouldnt I disconnect the IAC? It doesnt need it. I couldnt get it to idle with the accufab and it would die alot. It is just a pain in my ***.
Old 12-29-2006, 03:34 PM
ringram's Avatar
Well you can, but you will have to let more air in than you need for most times. The IAC helps with idle transitions like coming to a stop and low speed parking etc, where accessories load the engine which then has to add air to prevent a stall etc. Also Mr AC will load it up at idle. If you dont use IAC you are going to have to raise idle burn more fuel and generally be antisocial
Old 12-30-2006, 12:29 AM
ls1408cp's Avatar
The cam is so big it doesnt like to idle under 1100 anyway. I have no accessories. I dont drive this car but to race or just **** people up on the street.
Old 12-30-2006, 06:09 AM
phantom meneSS's Avatar
If driveability and throttle progression is not a problem then there is no problem although tuning will not be easy if you are worrying about anything other than WOT.
Old 12-30-2006, 11:09 AM
Mike454SS's Avatar
With a massive TB you're going to HATE how it drives at very low throttle angles (if you're stuck at a traffic light next to a police officer)...at least until you get used to it...make sure it's a VERY progressive linkage (cam on the throttle shaft) if it's a big TB.
Old 12-30-2006, 11:16 AM
ATVracr's Avatar
No you cant. Low TPS RPM tip in if it not a progressive linkage can be quite touchy, but in terms of torque output no you cant
GrannySS
Old 12-31-2006, 04:16 PM
ls1408cp's Avatar
any other thoughts on this
Old 12-31-2006, 10:27 PM
h.o.ls1's Avatar
... chris you crack my **** up on here
Old 12-31-2006, 11:29 PM
supersix's Avatar
I don't think you can.....take the harrop intake for example. It has 8 individual throttle bodies...we have been installing one at the shop. it is the 52mm version but that is still 416mm of airflow. Theoretically the more air the better......and when you get x amount of air your heads then become the restriction for flow. hope this helps
Old 01-01-2007, 05:52 AM
ls1408cp's Avatar
the itb intake would be way different which is the reason why it needs that much tb
Old 01-01-2007, 09:17 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Are you still on stock pcm?When i went from the stock pcm to BS3 the car just was so much more happy.The stock pcm was a PITA and it never did idle very well.When we put the BS3 in we almost got her to idle like stock.
Old 01-01-2007, 09:56 PM
Argon Z's Avatar
On an ITB intake manifold not all of the throttles are having air sucked through them all the time. On a plenum style manifold the throttle body almost always has air flowing through it.
This is because on a plenum style all the cylinders are pulling through the same throttle.
Hope that makes sense
James
Kinsler.com
Quick Reply: Can you over throttlebody a efi motor
