Questions on ramp rate and duration/lift
Is there a way to find duration at .006, knowing duration and lift at .050? Also, can ramp rate be found using duration and lift at .050?
Originally Posted by r351winner
If you know the advertised duration (.006) of a cam you can calculate the ramp rate. take the duration @.006 and subtract it from the duration @ .050. A number of 53 or higher denotes an XE lobe or other mild lobe and a number of 49 or lower denotes an XE-R lobe or other aggressive lobe
Here's an example:
XER 224/228 .581/.588
...........006 .050 .200
Intake: 273 224 146
exhaust: 277 228 149
LSK 224/228 .637/.639
Intake: 273 224 149
Exhaust 277 228 143
Hammer
