Homemade Octane Boosters - Page 3 - LS1TECH
Advanced Engineering Tech For the more hardcore LS1TECH residents
Thread Tools Search this Thread
Old 03-07-2007, 02:47 PM   #41
silverbandit0996's Avatar
so is there any disadvantage to running a Toluene gas mix in a DD?
silverbandit0996 is offline   Reply With Quote
Old 03-07-2007, 05:27 PM   #42
Quote:
Originally Posted by ejawodo
Don't forget that both Xylene and Toluene are highly carcinogenic. So be careful around it. It would be a good idea to wear nitrile gloves when handling it.
EVERYONE ATTENTION Gasoline is highly carcinogenic!! lets all get rid of our cars so we don't get cancer! (End sarcasm)
LiENUS is offline   Reply With Quote
Old 03-08-2007, 09:24 AM   #43
Quote:
Originally Posted by Z O SICK
I use the NOS brand (off road) and it keeps my cars from pinging and what not. Better safe then sorry.
Man, that stuff is SUCH a joke. It's not doing anything for you car except making it faster due to weight reduction ($$$).
Ben T.
Studytime is offline   Reply With Quote
Old 03-09-2007, 01:45 PM   #44
so from what i can tell, there is no reason to not use Toluene as an additive in a DD, correct or not?
Old 03-09-2007, 01:51 PM   #45
Quote:
Toluene will do nothing to your DD unless you have detonation or pining issues. It won't add power or hurt power. It will only cost you money you don't need to spend.
Ferocity02 is offline   Reply With Quote
Old 03-09-2007, 01:58 PM   #46
I would say if you need higher octane gas in a car that is a dd....detune it or just buy higher octane gas...i don't think you can add a can of anything to substitute for a safe substantial gain. If you have something that needs 116 octane go to the airport and get some....paint thinner and chemical x won't add 20 octane pts
toprintonbothsides is offline   Reply With Quote
Old 03-09-2007, 03:34 PM   #47
Quote:
i wasn't particulary talking about my car. but more along the lines of my buddies turbo laser so he could maybe up the boost.
Old 03-24-2007, 06:57 PM   #48
THE_SUPRA's Avatar
just throw some mothballs in your tank...
THE_SUPRA is offline   Reply With Quote
Old 03-25-2007, 09:44 AM   #49
Nate81Camaro's Avatar
^^Seriously hope your joking....
Quote:
Originally Posted by 1997bird
10 gallons mix
-1 pint of Tolulene
-1 pint Naptha
-1 5oz bottle of Rosenal lighter fluid (highest Benzene content)
-1 bottle of fuel injection cleaner for trace chemicals
What grade fuel are we starting out with, and what grade would that mix result in???
Nate81Camaro is offline   Reply With Quote
Old 03-26-2007, 05:47 AM   #50
Still waiting on a reply....
Old 03-26-2007, 02:19 PM   #51
Sorry to jump in so late, but about 20 or so years ago I spoke with a chemist at Union 76 regarding the addition of Toluene to gasoline. I seem to recall the reccomendation he gave was to not exceed a fairly low percentage; something like 15%. I also don't recall the reason why; something to do with diminishing returns. I subsequently opted to talk directly to the folks at VP. They were hugely helpful, and took thier time in discussing my needs. I came away with a very favorable impression of them. Basically it was easier to buy the right racing fuel for my application than it was *trying to play chemist.*
Andy1
Andy1 is offline   Reply With Quote
Old 03-26-2007, 06:53 PM   #52
toluene does eat up rubber... if i were gonna use it in my car (i have!!!) i'd make sure that it wasn't left in for an extended period of time. i only use it when i'm sure the gas will be ran out in a few days.
good luck
chris mac is offline   Reply With Quote
Old 03-26-2007, 08:03 PM   #53
whitt1's Avatar
I used to run 5gal of xylene with 15gal of 93 octane unleaded and a pint of transmission fluid as a lubricant.The mixture worked fine made 99 octane,but was a pain to mix,so I switched to Torco accelerator concentrated racing fuel,much easier.One can makes 20 gal of 93 octane into 97 octane.
whitt1 is offline   Reply With Quote
Old 03-27-2007, 10:11 AM   #54
Thanks, Andy/Chris/Whitt - that answered my questions.
I'm curious on this for my buddy's FI talon. I just wanted to know if we could use a mixture or if it'd be better if he bought VP when he goes to the track and turns his boost up.
Old 03-28-2007, 02:32 AM   #55
You could use any of the following (but in sparing quantities), refineries are already using some of them to "trim" final products to meet spec. The difficulty is we don't really know what is in the fuel to start with, so what do you add?
Ethanol RON115 - no more that 10% total.
Toluene RON115 - no more than 30% total - hardens/perishes rubber.
Isopropanol RON117
n-propanol RON117
(Also Isobutanol, n-butanol, sec-butanol and Isooctane {traded as alkylate})
Ethers (mix well with gasoline)
MTBE (Methyl-Tertiary-Butyl Ether) RON112
TAME (Tertiary-Amyl-Methyl-Ether) RON110
ETBE (Ethyl-Tertiary-Butyl-Ether) RON105
Additives (Generally not environmentally friendly)
Ferrocene (dicyclopentadienyl iron) adding 30PPM to RON80 fuel gives a +2
MMT (Methylcyclopentadienyl Manganese Tricarbonyl) adding 18mg/L to RON91.6 gives +1.5 - Generally used by refineries for trimming.
VYSSWagon is offline   Reply With Quote
Old 03-29-2007, 06:53 PM   #56
THE_SUPRA's Avatar
Quote:
yes im joking
Old 08-07-2016, 01:26 AM   #57
Quote:
Originally Posted by VYSSWagon View Post
Additives:
I can source Toluene locally..
Where does one purchase MMT ?
Fullpower is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Awful pinging bad gas.. need cheaper solutions. GMTheOnlyWay1 General LSX Automobile Discussion 13 04-15-2015 08:18 PM
home brew octane booster nastychevelle Advanced Engineering Tech 33 09-12-2009 05:49 AM
Xylene, octane booster Caribe Fueling & Injection 6 08-10-2008 04:48 PM
Xylene Plus Mystery Oil in Gas? C5natie Forced Induction 11 06-02-2008 08:52 PM
Where can I buy Toluene or Xylene from? (Specifically AZ) verbs Generation III Internal Engine 16 08-19-2003 08:08 PM
Tags
affect, cam, cold, fuel, gas, gasoline, high, homemade, li, marvel, mystery, octane, oil, race, racing, rating, service, starting, stations, toluene
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
