Advanced Engineering Tech For the more hardcore LS1TECH residents
Titanium Rods?
Old 03-06-2007, 06:16 PM
Forced370GTO's Avatar
Default Titanium Rods?
Are there any companies that are marketing titanium crank rods for our lsx motors?
Old 03-06-2007, 08:12 PM
6 & 8 Second Club
mrdragster1970's Avatar
not worth the money, I know guys running 2000+ HP and they don't use them
it was just a fad, but if you're that rich, there was a place called trick titanium,
check if they do rods.
Old 03-06-2007, 08:48 PM
comp builder's Avatar
Don't know of anybody that stocks them, but I do know GRP in Denver builds ti rods, everything we build gets their aluminum rods in it. I think the ti rods run in the $3000 range from them.
Old 03-07-2007, 08:31 AM
crazyfokker's Avatar
The factory LS7 rods are titanium. But their like $299.99 each.
Old 03-07-2007, 09:24 AM
CTSmechanic's Avatar
That return information could be to re SFI cert the bellhousing since NASCAR got on the SFI kick.. we have had to do that with quite a few things...
Old 03-07-2007, 09:39 AM
andereck's Avatar
I'm pretty sure Crower would be a good choice as they've built Ti rods for years.
Old 03-07-2007, 10:35 AM
427's Avatar
We have used titanium rods from Oliver, GRP and Crower in the past. The current set we have was made by Swanson Presicion Machine, he is the only one that would make them currently and they are around 500. each.
Kurt
Old 03-07-2007, 12:32 PM
andereck's Avatar
Aluminum is usually lighter in implementation
Steel
Titanium
Aluminum
Magnesium
Old 03-07-2007, 01:08 PM
RussStang's Avatar
Originally Posted by Genesis_26317
Aren't TI rods more likely to flex negatively???
Isn't that why Ferrari doesn't put Titanium blocks in their stuff since due to its flex it still needs extra reinforcement (like aluminum) so the strength increase isn't neccesary?
While aluminum weighs close enough to titanium the more exotic material isn't needed.
While exotic aircraft uses titanium because it flexes (in a needed manner).
I am pretty sure Ferrari's new F430 comes from the factory with Ti rods.
Old 03-07-2007, 01:50 PM
FieroBob's Avatar
To the best of my knowledge Titanium has the best strength to weight ratio of all metals. This is why it is most commonly used where you want parts that are very light and also very strong. That's my $ .02 worth.
Old 03-08-2007, 08:17 AM
If you want titanium LSx style rods, go to the dealer and order the stock LS7 rods. Thats your best bet.
Old 03-08-2007, 10:45 AM
Juiced's Avatar
Carillo and pauter will both make a ti rod, look to spend about 600-900ea.... they are only really used in roadracing engines where rpm and longevity is a must.
For allout dragracing and NO street use aluminum is best, if your doing both just go with a decent forged rod with good rood bolts, best being the Carillo rod with carr bolts
Old 03-08-2007, 11:33 AM
87gnx's Avatar
Ti is OVER RATED and wayyyy overpriced.It has been used in aviation for ever, and is now advertised in everything from razor blades to sneakers(forget what brand).You have some good suggestions above, use one of them, or???
Genesis are you sure your not thinking of valves??$.025
Old 03-08-2007, 11:50 AM
FAST LS1's Avatar
From the Trick Titanium site I'd like to see the draw press they use to stamp the titanium bell housings with, it must be massive.
Old 03-09-2007, 01:40 AM
chuntington101's Avatar
thats nothing! j/k
F1 guys have carbon fiber gearboxs!!!!
hmmmmm wonder what a carbon fiber rod would look like????? lol
anyone with photoshop want to try and make one????
Chris.
Old 03-09-2007, 03:48 PM
Boosted LS1's Avatar
I've been buying titanium rods from Crower at about $500 each. They take appx 3 months to make and are made from billet Ti as opposed to the ls7 items which are forged. The 1st set I bought weighed in at a tad over 500 gms. The last set weighed in at 491 gms. Guess that's good They are very nice rods.
Boosted.
Old 03-09-2007, 05:57 PM
^ I don't know but the wedged little end of the ls7 rod may make piston choice a bit more difficult as will it's bigger pin bore. Plus, the wedge has to make it a weaker rod overall and it won't be anywhere near as strong as a billet item. Once you revert back to .927" everybody will make you pistons. Guess it's about personal choice, cost etc.
Boosted.
Old 03-09-2007, 06:37 PM
Black02SLPSS's Avatar
Yeah titaniu gets lighter because you don't need as much it to make crap.
Out of that list only steel isn't flamible/explosive.
Aluminum is flammable? Maybe aluminum oxide in the presence of oxidizing substances and other metal oxides it is. But im pretty sure you cant take a chunk of aluminum and hit it with a torch until it sets itself on fire or grind on it until it flashes. Could be wrong but im almost positive it doesnt burn
Old 03-10-2007, 06:31 AM
Boosted.
alright boosted! good to see you on here mate.
you kept it quiet about running Ti rods!! what beast is that in????
thanks Chris.
Old 03-10-2007, 04:28 PM
^ Been here for 5 years matey but just changed my siggy 1 set are for HarryOz's 427 monaro turbo build. Another set are for a 427 n/a cobra. Oh and a 3rd set will be for my blown 427 TR8, eventually, lol. All Darton MID's.
Boosted.
Quick Reply: Titanium Rods?
