What Swirl Remover Do You Recommend?
Update. Posted pics.. Post #28
First off I do not have a PC or buffer So waxing and the swirl remover will be dine by hand.
This sunday will be the last day with the Trans Am as i am putting it away in storage for winter.
So here is going to be my process
Wash car with dish soap
Rinse and dry
Clay Bar
Re-wash car..... (car wash soap or dish washing soap???)
Rinse and dry
Swirl remover?????
NXT wax
Rinse and dry
Clay Bar
Rinse and dry
Swirl remover?????
NXT wax
Rinse and dry
Clay Bar
Rinse and dry
Swirl remover?????
NXT wax
Rinse and dry
Clay Bar
Rinse and dry
Swirl remover?????
NXT wax
that's exactly what i do using Dawn dish soap for both washes and 3m swirl remover with a $25 walmart polisher(10"). it isn't the ideal setup for paint correction but it does work pretty well
i dont think you can get the speed needed out of a regular buffer to get the most out of a swirl cutter. a buffer is only good for applying and removing waxes and such. for a swirl cutter, you need speed to work the product into the clearcoat. tropicare says to use a speed around 5-6 on a PC for swirl cutters. the highest speed is 6.....so you get the point. i wouldnt even bother with the buffer. theres nothing you can do with that that you cant do by hand. get a real PC. tropicare sells a starter kit for under 180 i think.
either way, 3M finesse-it and tropicare swirl cutter are the best ones ive seen. ive used megs swirl cutter, but it did nothing for swirls. made it shine extra nice though. more of a polish then a cutter.
I would seriously recommend buying a Porter Cable 7424. I've used one for years and it's worth the price the first time you use it. Most of the better swirl/scratch removal products require the heat generated from high speed to work properly. In addition, using the correct application pad is just as important for optimal results. It's the only way to go if you want to truly remove swirl marks and minor scratches. I use Menzerna products, but never would bother using them by hand for an entire car. In the meantime you can use a glaze before applying the final polish to help fill the smirl marks.
cool i'd like to see a couple pics of your car, it looks really clean. i have no idea who jim is though (matt) you can get a pc at tropicare----> or any online tool store. they used to carry them at Lowes but the stopped stocking them around here at least
The PC is 169.99 plus shipping. It comes with the buffer, backing plate, counter weight, pads and bonnets. It also comes with small sample bottles of the car wash, polish, detail spray and swirl cutter. I am the Tropi-care rep for Houston and stock most of the products as well as the buffer kits.
I don't use Dawn on my paint anymore.
The swirl remover should clean up the paint, and isn't as harsh.
Dawn is for dishes.
I really like Prima Swirl, but lately I have been using Menzerna polishes.
I do a 4-5 step process on mine though. At least 3 of them with a PorterCable.
PorterCable.
Random orbital buffer.
Dawn is for dishes.
PorterCable.
