Rock Chip
Rock Chip
Im about to put on the Manta Stripe... but i have a rock chip that will make the stripe not sit right... how do i get it flushed anyone know a way...??
you could slowly build up the chip w/bondo or glazing putty or you could use paint that matches and do the same. You must restrain your self and only do a dab at a time. The bondo/glazing putty will shrink once it is cured. Just keep doing this until it is flush after curing. You may have to wet sand a little and then the stripe will look great and no one will know about the chip.
