Clear corners
yep on my last set i had in my car had the same problem was burning the bottom and yes it will make a hole eventually , but bought another set even had them tinted dark but never installed them i planned to put led's in there to eliminate the heat problem but just put my stockers back and now have the clears for sale...
Im looking for some, good to know what will happen ahead of time.
Anyone using the clear corner's from RKSport?? Only place ive seen them avialable, tried Afterthoughts Auto but there on back order.
They will work but flash very fast because LEDs consume much less power than a standard filament bulb so the car think the bulb is burnt out and flashes rapidly to let you know. LED flasher will be needed.
As far as an electronic flasher goes, you should be able to pick them up at any auto parts store.
