Sponsored by: DashLynx
Painting LS1
Old 12-12-2008, 12:25 AM
ZMONSTER!'s Avatar
Default Painting LS1
Hey just wanted to know what the best way to paint a block is? What all would I have to mask? Could I just pull pull the block out yank the headers off and paint? or would I need to mask every spot that has a gasket?
Old 12-12-2008, 01:50 AM
sway99bird's Avatar
Just like you said I think any part of the block that has a gasket should be left alone. A what color are you thinking of painting it?
Old 12-12-2008, 02:02 AM
ZMONSTER!'s Avatar
Only one color to paint a chevy block, and thats chevy orange!
Old 12-12-2008, 07:23 AM
Fast_94_Z's Avatar
if you left it mostly assembled you have to mask off everything you dont want to get paint on. some people end up doing the ends and oil pan but if it were me i would just paint the engine block and thats it. my personaly favorite way to paint a block is use basecoat clear coat. with holds the best and looks the best. some people will tell you just to rattle can it though.
Old 12-12-2008, 07:49 AM
BIG_MIKE2005's Avatar
I'd say the only time I'd even consider painting a block would be if it was fresh from the machine shop & you cleaned the outside of the block very well to ensure no oils are on the metal your painting. Otherwise any paint you use is gonna look like crap later if painted over a dirty greasy surface.
I'm gonna paint my block while building my spare motor up. I'm just gonna use high temp brake caliper paint & call it good. Thats what I used on my coil packs to paint them red & it's holding up great. You will need to plug & mask off every gasket surface & hole in the block you don't want paint to get into also.
I would venture to say the best way to paint it would be on a rotating engine stand so you can see it from all angles.
Old 12-12-2008, 04:59 PM
ZMONSTER!'s Avatar
ya this sadly probably wont happen soon, but this is my insperation...
Old 12-12-2008, 06:38 PM
Rai
Rai's Avatar
Originally Posted by zmonster!
only one color to paint a chevy block, and thats chevy orange!
+10000
Old 12-12-2008, 07:06 PM
5PONT7's Avatar
I approve!
Old 12-12-2008, 07:16 PM
shtnfrds's Avatar
why caliper paint? just use engine paint, they do make a paint specifically for what the OP is going to use it for.
Old 12-12-2008, 07:28 PM
homerunhtr21's Avatar
Fill a really big bucket with orange paint, dip the block in it for about 10 seconds, lift the block and let the extra paint drip off. Should work pretty well.
Old 12-12-2008, 07:31 PM
ZMONSTER!'s Avatar
now would a rattle can application work? Pretty much the only option I have unless I can pick up a cheap paint gun.
Also Ive never seen anyone paint the cylinder heads, is it dangerous? I wouldnt think so But I might as well ask
ZMONSTER!'s Avatar
Wait a minute are you serious?
Old 12-12-2008, 07:37 PM
ZMONSTER!'s Avatar
one thing that has me confused about the pics I posted above is that the exhaust ports and gasket area weren't masked off, hell there is paint in the exhaust port! Would paint in the gasket area for the engine accessories(intake/headers/water pump/etc...)cause a bad seal/be a bad idea?
Old 12-12-2008, 08:33 PM
shtnfrds's Avatar
if you paint anywhere a gasket is supposed to go, i would scrape it with a razor blade or carfully use a grinder with one of those green plastic finger wheels on it. id think the paint on the gasket surface would make for a leak soon. and yes rattle can work just fine. go to autozone or whatever and go to the paint section. all the high temp stuff is useually on the top shelf. kinda pricey, but its made to do what your going to do with it.
Old 12-12-2008, 09:57 PM
LawmanSS's Avatar
You definitely should avoid painting the gasketed surfaces. I can't believe that engine in the pics has the exhaust ports painted.
Old 12-12-2008, 09:59 PM
ZMONSTER!'s Avatar
Ya kinda had me confused, but it looks soooooo good.
Old 12-13-2008, 08:46 AM
Well I have tried the engine enamel but it just didn't look as good to me after it dries as the caliper paint.
Old 12-13-2008, 12:41 PM
ElectronSS's Avatar
this was done 3 stage with engine paint and some spray can.
used ford lite blue engine paint as base, then blue pearl for top color, then engine clear. motor to this day still looks as sharp as this
Old 12-13-2008, 06:43 PM
buellxb12s's Avatar
i like the Screaming Eagle Springer in the background
Old 12-13-2008, 07:30 PM
In no way, shape, form, or fashion was I anywhere close to being serious...Just a little humor to get me through a boring day.
Quick Reply: Painting LS1
