Sponsored by: DashLynx
Old 05-20-2016, 02:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Lighting Guides
Print Wikipost
HOW TO: Sequential Tail Lights
Old 05-17-2010, 12:10 AM
  #61
99FBirdForm's Avatar
http://s784.photobucket.com/albums/y...t=P5160007.flv
Not sure how to embed a Video in the thread so here is a link to the vid...I just did this the other day, took less than 30 mins. IMO they sequence WAYYYY to fast. Is there any solutions for this?
Old 09-26-2010, 03:08 PM
  #62
Fosnot's Avatar
Originally Posted by xXxSilveradoxXx
Did you change your outside bulbs to dual filament or did you leave them single? If you left them single get a video with the lights on, I'm debating whether I want to keep the outside bulbs single or go with duals.
I went thru the thread, and couldn't find weather or not anyone decided on dual or single filaments.
I'd think you'd have to have a dual filament, but maybe I'm wrong?
Old 10-18-2010, 09:12 PM
  #63
1strookie's Avatar
I just ordered me a set that has just been delveloped for 1999 to 2002 trans ams.Says plug and play.Still have to change flasher for use leds.89.95 Ill post back after I get it.No longer have to modify the third socket with this kit.
Old 10-18-2010, 09:14 PM
  #64
osuhog's Avatar
Sweet, let us know for sure, I am very interested in your results.
Old 10-19-2010, 08:31 AM
  #65
99_Z_155's Avatar
I used 3157 double filaments on the outer positions. big mistake. they make alot of heat. when i was in traffic with my foot on the brake , the lenses began to melt and bubble. so i bought a new set of lamps, and i bought 3157 tower LED bulbs to fit into the 3157 sockets. they look great, and they make no heat, or at least not enough to melt anything.
Old 10-21-2010, 07:27 PM
  #66
1strookie's Avatar
Talking sequential tail light for trans am fianally
They came in today and I put them on this afternoon.Truly plug and play.I did not have to purchase anything additional.I spent about an hour installing you could rush and do it in about half of the time.I did change the bulbs over to the newer sylvania bulbs that are supposed to be 40% brighter.Not sure how well they will work with the led bulbs.The kit comes with different bulbs to use on the outside and it supplies dual voltage to the existing socket.Works perfectly.I will get a video and try to post.
Old 10-23-2010, 09:44 PM
  #67
1strookie's Avatar
here is a link to video.The lights are the same brightness.I have the famous dimmer appearing tail light on the driver side until I find a new one.
http://www.youtube.com/watch?v=jcTYqKkq7Ac
Old 10-29-2010, 02:50 PM
  #68
osuhog's Avatar
Awesome man, thanks for posting your results. Where did you get this plug & play kit at? Thanks again!
Old 10-29-2010, 02:57 PM
  #69
chaman's Avatar
^^What he said!
Old 10-29-2010, 03:14 PM
  #70
chavez885's Avatar
Anyone know how to slow down the sequence on a camaro? The video of the yellow camaro LT1 lights is how mine are now, but I'd really like it to go slow. Anyone messed with this?
*edit* Did buy a diff flasher but it didn't really change anything. Is there a certain one to buy that is slower? Thanks.
Old 10-29-2010, 08:06 PM
  #71
xXxSilveradoxXx's Avatar
I'm pretty sure that there is an adjustable electronic flasher that's available for our cars. I'll have to look for it again.
Old 10-29-2010, 08:28 PM
  #72
_JB_'s Avatar
Man I hope so, I've had sequential tail lights for years and always wanted to slow mine down.
Old 10-30-2010, 05:11 PM
  #73
gm02ceta's Avatar
YES Could you please PM us where you can purchase the kit!
Old 10-30-2010, 05:50 PM
  #74
chaman's Avatar
Interested in the PM also!
Old 10-31-2010, 10:38 AM
  #75
Copy & Paste Moderator
VIP1's Avatar
Me too. I'd like to know.
Maybe I missed it above, but do I still need to change the outer bulbs to be dual filament?
Old 10-31-2010, 10:41 AM
  #76
1strookie's Avatar
Default where to
Ive put about 1000 miles on it since installing them.No problems so far.The kit is 89.95 with free shipping.There is nothing more to purchase.They supply dual voltage to the third light doing away with the need to change sockets.They also update the bulb to the 921 which handles the extra current.All three light up at the same time as a running light, and all three blink.Any questions just ask even if you run into a problem during install.Ill post the address not sure if its legal or not but if not mods remove and peeps can pm me.WWW.webelectricproducts.com you can get a fully adjustable flasher but with the stock bulbs they blink fine.I am considering trying leds but havent yet.They just developed this kit about 3 weeks ago so its still new.But like I said no problems here at all.
Old 10-31-2010, 10:45 AM
  #77
1strookie's Avatar
Default vip1
No you dont change to dual filament bulbs.They alter the current to work with a single filament bulb but they do change the bulb to a 921 which is included.No changing the socket.Completely plug and play!!
Old 10-31-2010, 11:09 AM
  #78
VIP1's Avatar
Unfortunately, an LED replacement wouldn't work in that outer socket with that dual voltage setup. I'm guessing the sequencing units output 6V / 12V to the outer bulbs depending on operation (parking lamp vs brake/signal). If you put in an LED unit, it would turn on at 12V and stay off at 6V because its been designed to with at 12V.
Old 10-31-2010, 11:46 AM
  #79
JOHNNY59's Avatar
where can I find a fully adjustable flasher, so I can slow down the flash rate of my lights?
Old 10-31-2010, 02:22 PM
  #80
1strookie's Avatar
they said they didnt think it would work with the leds because of the dual voltage to the outside bulb.I personaly dont know much about leds at this time but was going to try anyway...until now.Im sure that the reduced voltage would prevent it from working.As for the adjustable flasher I havent purchased one because I like the way they are.However Im sure that the ones you use for leds would work fine as they supply the current to the lights
Quick Reply: HOW TO: Sequential Tail Lights
