LED Gauge Cluster Lights - Page 5 - LS1TECH
Thread Tools Search this Thread
Old 03-16-2009, 10:38 PM   #81
red01camaroz28's Avatar
Quote:
Originally Posted by fbodyrs96 View Post
super bright LEDs are built in and if they don't light up turn it around and try again..this is what I had to do to mine..
I had to pull the leads up and wrap them around the connectors..
Well I don't have the bulb like this, but I have the Neowedge 3mm LED in white and the wire doesn't reach the posts. Did you have to add more wire to reach the posts?
Oh and also where is the bulb on the headlight ****? I can't find it!
red01camaroz28 is offline   Reply With Quote
Old 03-17-2009, 12:34 AM   #82
fbodyrs96's Avatar
3mm neo is for the headlight switch, it should just untwist and twist the new one in..
fbodyrs96 is offline   Reply With Quote
Old 03-17-2009, 12:45 AM   #83
myc4ltwon's Avatar
I'm interested in the kit. I'll have to PM him!
myc4ltwon is offline   Reply With Quote
Old 03-17-2009, 09:49 AM   #84
99_Z_155's Avatar
form my 96 should be the same for 93-96
The blue's that i got for my 99 look much like this color. however, i have macewen overlays in silver, and the red areas dont really show. if they do its like a purple. i guess its something im gonna have to live with. but it does look killer at dusk when you can see the blue and silver together. brings a smirk to my face.
99_Z_155 is offline   Reply With Quote
Old 03-19-2009, 10:23 PM   #85
perfectz28,
were the WLED's you used the 5led version? i was thinking using the 4led in blue..
stealth355tpi,
i see you got the WLED-xHP High Power LED bulb for the cluster. but which ones for the rest of the interior.. are they the same as the already metioned or did you go with different versions.. and for the fog light switch what led is that or did you have to solder one in with a resistor. if so what style. im also going to be doing the radio lights..
im want all blue leds, its just the blue just dont look bright enough for me.. s
Eiyse98ls1 is offline   Reply With Quote
Old 03-19-2009, 11:42 PM   #86
guys,
can you post the exact bulbs/led used with the pics so we can decide what are the best for us to use..
stealth355tpi the brightness on yours are perfect only if we can get that in blue..
Old 03-20-2009, 11:43 AM   #87
PERFECT Z28's Avatar
Quote:
Originally Posted by Eiyse98ls1 View Post
perfectz28,
I used the WLED-x5's
PERFECT Z28 is offline   Reply With Quote
Old 03-20-2009, 03:47 PM   #88
maxgee's Avatar
Which bulb on super.... com is the rear cargo bulb 561 replacement?
maxgee is offline   Reply With Quote
Old 03-20-2009, 05:12 PM   #89
Quote:
by the # it is 4410 w/ rigid loop. but the way it mounts wont work in the rear cargo because the led's wont face downwards they will face eaither towards the back or front. i actually got one ordered of ebay that has te led's mounted the correct way.. just do a search on ebay for 561 and you will see what im talking about. theres type a and type b.. type bis the ones we need in the rear cargo for camaros not sure the rest..
Old 03-20-2009, 05:13 PM   #90
Quote:
thanks.. so those blues werent bright enough so i may just go with the hp in blue.
Old 03-20-2009, 11:29 PM   #91
The blues were too blue for my color scheme so I ordered the cool white.
...just to make it clear, I have the 6LE gauge overlays so whatever color LED's I use THAT color shines through...
Old 03-21-2009, 07:22 AM   #92
maxgee's Avatar
I ordered the dash xhps and door and hvac bulb yesterday and now looking for the cargo bulb.
Old 03-23-2009, 08:15 PM   #93
If im not mistaken but you do need some sort of color with the new 6LE gauges so that they will shine through correctly, i've got a trans am so will all i need is 5 WLED lights (WLED-x5 LED Wide Angle LED bulb) and I will have the stock red look shining through at night?
zlover129 is offline   Reply With Quote
Old 03-24-2009, 06:09 PM   #94
so ummm....where'd everybody go?
Old 03-24-2009, 08:00 PM   #95
Quote:
yes what ever color leds you put will shine thru the 6le overlays.im not sure how many wled you will need i need 7wled's for my 98 camaro. i beleive if you use white led you would be probally show red becuase of the film. dont quote me on that since i have a camaro. but if you change color of leds that may be a difrent story.
Old 03-27-2009, 10:28 PM   #96
maxgee's Avatar
how do you remove the bulbs in the doors?
Old 03-27-2009, 11:32 PM   #97
hard to explain. but follow the link. all you need to to do a couple of the steps.
http://shbox.com/page/windowmotor.html
Old 03-28-2009, 10:26 PM   #98
just installed my blue led's i needed 6. not 7. pics soon
Old 03-29-2009, 09:19 AM   #99
I had to order nine bulbs myself, just went ahead and got a red LED for every single bulb on the back, 2 green ones for the turn signals and 1 blue one for the high beam, and the other 6 are red, looking forward to getting them in.
On a side not, i ordered mine from superbrightleds andi must say the customer service is one of the best i've had. There is a spot for comments when you place your order and went ahead and did the standard USPS shipping (last thurs.), i put in the comments that i would like to have them by next wed and if this shipping wouldnt be sufficient then go ahead and upgrade me. Got a phone call while at work from a strange number, didnt answer, he left a message telling me that he read it and said that he couldnt gaurantee it to be there on time but UPS he could. He then called AGAIN a few hours later and this time i answered. They're a bit pricey, but idk about you guys, i'd rather pay a little extra and get the support with the product as well. Good company imo, now i just cant wait to get them and install me new overlays and gauges.
Old 03-29-2009, 09:52 AM   #100
fbodyrs96's Avatar
well I change mine form blue to red, much brighter and easier to read at night...
Related Topics
Thread Thread Starter Forum Replies Last Post
? About map light LEDs HappySalesman Appearance & Detailing 6 03-17-2016 03:28 PM
LED gauge lights help!!!! mcginnis22 Appearance & Detailing 8 01-29-2016 08:05 PM
Correct LED interior lights? JTtransAM Appearance & Detailing 5 04-15-2015 03:14 PM
What leds for 98 gauge cluster, dome and map lights? Mr. Trick Appearance & Detailing 2 04-06-2013 05:21 PM
Anyone have a firebird/TA with full LED interior? Slash8915 Appearance & Detailing 1 09-14-2011 05:04 PM
Tags
1995, 2000, 74rhp, 98, blue, camaro, cluster, clusters, custom, gauge, hvac, leads, led, lights, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
