Connector for A/F gauge
I just bought some autometer gauges and have a question about the a/f gauge and how to hook it up. I know there is a pig-tail plug that can be used, and is probably best. However, could i just use a dual splice connector on the purple/white wire (pin 69) coming out of the pcm? It would keep me from cutting the signal wire while still being able to splice in the purple wire from the gauge. Only reason i ask is because I know some people have had trouble with inaccurate voltage signals after cutting and splicing into the purple/whit signal wire. Also, what gauge wire should i run from the supplied purple wire from the gauge (which is really small) to the purple/white signal wire? Maybe 18 gauge?
Attached is the splice im talking about using.
^^Okay cool so those connectors should work. Im not certain ill splice it at the pcm, i might go down through the shifter area and tap in closer to the o2 sensor that way.
And yeah trust me i know about the narrow bands, this is just a filler gauge till i boost or spray the car lol. Plus i got the gauge at a really good discount.
