TA door panels in a camaro?
will door panels out of a TA fit in the same gen camaro? i tried searching but couldn't come up with an answer. i just like the speaker and tweeter setup of the TA alot better. they dont look as "cheap" as camaro panels
I think you are lying about searching, here are a few threads I found running a search with threads with "door panel" in the title only. I am sure you would find more expanding the search parameters but you don't need too, it is very easy. Take off the door panel, cut off the 2 tabs it screws to, put in the trans am door panel. Thats what I did. If you are going to do it get an ebony set, I got grey then regretted it and got ebony and they run $100 + a piece.
https://ls1tech.com/forums/appearanc...anels-z28.html
https://ls1tech.com/forums/appearanc...ls-camaro.html
https://ls1tech.com/forums/appearanc...-1995-z28.html
https://ls1tech.com/forums/appearanc...anels-fit.html
https://ls1tech.com/forums/appearanc...camaro-ss.html
