side molding removal
so im in the process of removing the side molding of my camaro...i have to say this project is taking alot longer than i had planned...this glue residue is really hard to get off...i have been going for hours with a can of wd40 and its coming off but damn haha...i was curious if there is any other product that removes glue residue better than the wd40 im using...thanx
I heard of it, but never tried it. When i did mine, i used some degreaser that i jacked from work lol. It worked great, but overall the glue wasnt that hard to remove on mine. Most of it came off with the molding. goo gone will work.
EDIT: now that i think about it, i really didnt use the degreaser all that much. Get the hair dryer and heat it up and try to remove it. that should help out some.
If you cut it off with fishing line most of the time the glue residue is much less. But at any rate heat is your friend...heat it up and rub it off with your finger (using a glove!) Without heat it is a PIA to get off! Also I am always fearful of pulling the paint off if you dont use heat to soften the glue.
if their is alot of adhisve left I use an eraser wheel that you can get at autobody stores, but be careful it can burn through the paint. If their is only alittle left I use 3m adhisve remover.
i hear you on that one man...where i go to school the parking spaces are so small...they tried to fit as many spaces into the lot as possible...and now everyones doors pay for it luckely not mine (knock on wood) and cuz our doors are so freakin big compared to most cars i have to do these acrobactic moves just to get out of the car haha
