What Paint Do I Need For The Following....
I want to paint my brakes, valve covers and coil packs. I really do not have the money for powder coating My car is not a DD so i am not too worried about the paint chipping...
So what type of paint for the above items (what temp rating)?
What type of primer?
Do i want to use adhesion promoter primer?
Clear?
Thanks. When the weather breaks i got some projects that i need to start workign on
Clear?
Clear?
Clear?
The brake calipers you can go with a standard metal primer and your choice of caliper paint and high-temp clear. I've had great success with Duplicolor and VHT products.
You can use primer, high-temp paint or caliper paint, and a high-temp clear for the valve covers. The same for the coil packs, but I'd take it a step further and use some adhesion promoter on the coil packs since they are plastic. It would only be like $5 more for the can of adhesion promoter.
Can i use the same stuff on my valve covers, rear diff and coil packs?
the stuff that i want to paint, does it need a caot of primer?
All i need to do is pick up some adhesion promoter, primer and some clear.
Jonas, this is what I did - not saying it is necessarily the right way, but it worked well.
Sanded the brakes to get them smooth, cleaned with brake cleaner, sprayed 4 coats of high temp red paint, then sprayed with 2 coats of high temp clear.
I used this process on my brakes, and coil packs. Worked like a charm. I have had no problems with chips etc. I still have to do my valve covers, but I will use the same technique.
-Adam
-Adam
