Power to manual windows
Looking for any information to swap the power windows in a trans am to the manuall cranks from a v6? I'm building a drag car and the passenger side goes real slow and both switch housings are broke.
Should be possible. the whole exists in the door already, so you need to pick up the crank parts and inner door panels for your car from a junk yard. or just get replacement switchs for the windows from the junkyard.
Slowness is either a motor burning out if its slower than its normal slow self. Or just the fact that they are running to link of a power wire at the wrong gauge.
Eventually I'll add a relay and direct power tap for the pass window to feed power direct from the battery.
