Sponsored by: DashLynx
Scratch removers???
Old 04-13-2009, 06:31 AM
bski224's Avatar
Default Scratch removers???
Need to know whats a good solution to remove scratches that are not through clear coat?? I tried the clay bar and not some much luck. Any info!!
Old 04-13-2009, 07:14 AM
Nova5's Avatar
Clay bar is a contaminant remover. how big, how many, how deep are the scratches? are the circular or lines?
Old 04-13-2009, 07:31 AM
Nightrydass's Avatar
3M has a rubbing compound that i used; it is supposed to get out 1500 grit sand paper scratches and swirls, ect. I used it last weekend, i cut the **** out of my paint, BLACK paint. It came out AWESOME. I used a random ordbital and it worked great. The only thing i need to warn you about is that it leaves A LOT of white dust that is annyoning to clean up afterwards. you can find this **** in the same isle as paint and bondo @ Pep Boys.
Old 04-13-2009, 10:32 AM
LS1TECH Sponsor
Steve P's Avatar
Powder based polishes and compounds like 3M and Menzerna create a fair amount of dust as they break down on the surface during buffing.
We get a lot of inquiries from f-body and other owners looking for recommendations to improve their paint surface conditions. We have a lot of success using Menzerna Super Intensive Polish to remove these circular and random scratches on harder clear coats. It is a very fine textured polish that cuts like a heavy compound. Using the FLEX machine, results can be pretty fast with dramatic improvement. The PC will also achieve these type of results just taking a little longer.
To inspect the results, swab the surface with 50/50 mix of IPA and water.
This removes any fillers, oils and residue so you can see any remaining defects.
Old 04-13-2009, 06:17 PM
BitViper's Avatar
Uhhhh whats IPA?
Old 04-13-2009, 07:40 PM
wannafbody's Avatar
By hand, Megs Ultimate compound or Swirl X- Ultimate compound works great by PC as well.
Old 04-13-2009, 08:12 PM
PSU 98's Avatar
Originally Posted by BitViper
Uhhhh whats IPA?
Isopropyl (Rubbing) alcohol. Cheap alternative to all those "final inspection" products
Old 04-14-2009, 06:38 AM
SS LeadFoot's Avatar
Zaino Z5 works for me. If its a huge deep scratch I would try something else... knock on wood ive never had one.....yet
Old 04-14-2009, 07:20 AM
SLOW 94 LT1's Avatar
I scratched my front bumper on my Black SS a month ago when I pulled out the headlight. Got some Meguiars Scratch-X for the hell of it. Worked GREAT. Couldn't tell I did anything to it. For like $12 a bottle, it was well worth it!
Quick Reply: Scratch removers???
