Painting the valve covers
Ok I was thinking of painting my valve covers my body color which is SOM. Now how long
would that paint hold up for if I have a body shop prime it paint it and clear coat it?
Re: Painting the valve covers
It should hold up. Have him bake them in the spray booth to heat cure the paint (just like they do for a car). The valve covers get hot but not any hotter than a black hood at noon in the Arizona sun. If the paint should ever fail due to heat you could always repaint them.
FYI, I painted my valve covers using the same paint I used to paint my brake calipers. I believe it was 500F temp paint. Got it from Pep Boys. As for painting the covers, I didn't use a primer or a clear and over a year later these things look the same as the day I painted them.
There isn't much instruction to give on how I painted them (pretty simple), but here goes:
1. Remove covers. Remove gaskets, oil filler, etc.
2. Thoroughly clean the covers. I started off by rinsing them with a hose and using engine degreaser to get the majority of oil/dirt/grime off. Then I used a pretty coarse sponge and some soap/water to finish cleaning. Note: There were a few "rough" areas one the covers, left over from when they were manufactured. I used some fine sandpaper (~600 grit) to smooth these areas off. Before painting them I cleaned them once again to get off any dust.
3. Place the covers on a flat surface. I put them on newspaper, on my garage floor. Tip: Tape the edges of the paper to the garage floor to prevent it from accidentally flipping over and sticking to covers during painting.
4. Paint away! I laid down a large quantity (~8) of fine, even coats. I waited ~5-10 minutes between coats. I kept going until I was satisfied with the texture and coverage.
5. Let dry overnight and re-install!
<img src="http://www.softcom.net/users/ericg/zbusasig1.jpg" alt=" - " />
Eric - 1999 Camaro Z28
Performance: ARE Stage II H/C,Superchips Programming,Nitrous Express,LS6 Intake,ASP Pulley,FLP's,Borla,Whisper,Ported TB,SPEC Stage3 Carbon w/288 Slave,B&M Ripper w/ Momo ****,HP 160 Tstat,MSD Wires,NGK TR6,BFG DR's,!FRA,!CAGS,Mobil1
Dyno: Before H/C, N/A: 318.3 rwhp, 326.9 ft*lb torque
Dyno: H/C w/ MACS, N/A: 404.5 rwhp, 381.4 ft*lb torque
Dyno: H/C w/ 100 shot nitrous, A/F < 10.0!: 478.5 rwhp, 500.3 ft*lb torque
Suspension: Eibach Prokit,Metco LCA's,BMR STB,Lakewood APHR
Appearance: 18x9.5" Budnik Tillers w/ Nitto NT555,Wings West Grille(red),APC Clear Corner Lenses,SuperWhites,Red Calipers,Tint
Stereo: Clarion 7475 CD,EQH-5100 EQ/XOVR,Soundstream Reference 644,Diamond Audio Hex components,3 JL 8W6's
Other Performance: 2001 Suzuki Hayabusa: D&D Carbon Fiber Slip-ons,Timing Retard Eliminator,K&N,GSXR-750 Pegs,Zero-Gravity Windscreen,Gen-Mar Bar Riser,Lockhart Clear Signals
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ericwg:
<strong>FYI, I painted my valve covers using the same paint I used to paint my brake calipers. I believe it was 500F temp paint. Got it from Pep Boys. As for painting the covers, I didn't use a primer or a clear and over a year later these things look the same as the day I painted them.
5. Let dry overnight and re-install!</strong> </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Eric,
Thanks for sharing how you painted your valve covers! Our members will appreciate the info!
Andy
<small>[ May 29, 2002, 07:54 AM: Message edited by: Xsta Z 28 ]</small>
Andy
Yeah, have speed inc powdercoat them...unless you still have your body shop connection. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
You could maybe get them powder coated for less than a body shop would charge and it would never flake off or bubble up I think, and it would not scratch as easy as paint.
