removal of front camaro grille
Re: removal of front camaro grille
When I replaced mine I took off the bolts under the car by the air dam, reached behind the grill and pushed the tabs out. You will still have 2 or 3 bolts holding the grille on. I had a friend pull the grille out far enough that I could get a pair of big scissors behind it and cut the plastic "screws" that are molded to the back of the grille. Once I got the grille off I just hit the fascia where the "bolts" were and they fell out through the bottom.
This wil obviously ruin the stock grille but I do not plan on ever putting it back on <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
What I did was remove the whole front bumper <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . I like takeing this apart. It was kinda hard geting to the bolts around the headlight area(3 or4 eachside), but i managed. I was first going to yank it off, but didnt want to go through the trouble of finding another. You know just in case.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tapout:
<strong>it can be removed by just pulling with some force.
Thats how I did mine.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Same here
I just yanked REALLY hard.. and it came out <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<img src="http://home.attbi.com/~seph5150/Images/KIF_0382.JPG" alt=" - " />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by z28man:
<strong>just by pulling it out with force, is there anything to break?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Some of the mounting stud to the old grill may break. Just make sure while removing it that you are appling pressure to the front end of the car, so that it doesn't move/stretch or crack.
it was not that bad to replace the factory grille! about 2 hrs i was done and had half a cold one down! thanks for the help people!!!
1 Post
I will vouch for the yank hard then harder method. . .BUT I ended up damaging the grill (which was removed anyway). Can't reuse the thing now though
BUT it does come off that way. . .
Yank carefully. . . .
you can pull out all the lower facsia pins and bolts then reach in behind and undo the nuts from the top of the grille. I think there are 3. The bottom ones are push on clips. You can flex the bottom of the fascia enough to get your hands in there if you remove all the attaching hardware at the bottom.
