2002 Trans Am door panels in my 1995 Z28 !
I have had alot of questions regarding this appearance mod that i did, so i just thought i'd make a post about it
for anybody wanting to see if it was possible, here ya go !
2002 WS6 Trans Am door panels and leather seats in my 1995 Z28
Up next is a 2002 WS6 Trans Am complete dash into my 1995 Z28
here are some pics of what i had to do!
trans am power mirror plug on the left and camaro power mirror plug on the right! (i still haven't modified the harness yet to put the t/a plug on the camaro harness)
the camaro power window harness plugs right into the t/a window switches (no modiciation at all) and the power lock harness plugs right into the T/A switch
the factory camaro inner door skin (shell) i had to modify by cutting the mounting points for the camaro door panels off, due to them protruding out too far hindering the mounting of the t/a door panels.
i also took the square plastic snap in nuts (grommets) out of the pieces that i cut off, and drilled new holes in the inner camaro door skin (shell) to relocate the mounting points for the t/a door panels.
you can determine the new mounting points for the t/a door panels by hanging them on the door and taking a drill and drilling thru the factory door panel screw holes into the camaro inner door shell (skin)
