Sponsored by: DashLynx
FRC install with my setup...?
Old 11-18-2003, 02:13 PM
joshs2000ss's Avatar
Default FRC install with my setup...?
I've seen the pics of people installing FRC's on a basically stock engine. I'm wondering if anyone has done this with the EGR/AIR system removed and how much, if any, easier that will make it. Will I not have to cut as much? Any info would be great.
Thanks,
Old 11-18-2003, 02:24 PM
WhiteDeathLS1's Avatar
Thanks,
The EGR has little, if anything, to do with a FRC install. The 2000-02 F-bods will require a bit more cutting on the driver's side due to the air system.
Old 11-18-2003, 02:52 PM
I don't have any of those hoses in my engine bay.
BTW, it's an M6 if that matters.
Old 11-22-2003, 01:50 AM
parbreak's Avatar
You'll still have to cut out for the throttle cable bracket and the dipstick
on the passenger side and perhaps a little in the rear to clear the wiring
harnesses. You should be fine on the driver's side with no cutting if you
don't have the AIR anymore.
Bryan
Old 11-22-2003, 07:15 AM
Administrator
unit213's Avatar
I agree with parbreak.
To answer your question more directly, yes...it will be much easier without the damned AIR hoses.
Quick Reply: FRC install with my setup...?
