Bulb to LED List - Page 12 - LS1TECH
Bulb to LED List
Thread Tools Search this Thread
Old 09-06-2012, 08:46 PM   #221
stealth355tpi's Avatar
i pulled the stupid light holders off the bezel and glued the face of a single led over the hole. plenty bright enough and both the same brightness.
stealth355tpi is offline   Reply With Quote
Old 09-07-2012, 11:42 PM   #222
sjsingle1's Avatar
both my door lights are equally as bright after leds
sjsingle1 is offline   Reply With Quote
Old 09-08-2012, 08:07 AM   #223
juSStin4171's Avatar
I'm about to order but just to be SURE...
Will these work for my guages (Tach, Speedo, etc.)???
https://www.superbrightleds.com/more...-base/206/920/
juSStin4171 is offline   Reply With Quote
Old 09-08-2012, 07:50 PM   #224
zfastss's Avatar
Those look like the ones people seem to be using and should work fine. The alternate is the WLED x5 which people also claim works just fine (you linked to the WLED xHP5). Theoretically the xHP5 that you are looking at should be a little brighter...keep in mind though that the blue color might not light up the red parts of the cluster as well as a white bulb would. The benefit of our camaro cluster is that there is a blue film over the letters so if you use a white led bulb, the numbers will still shine pretty blue (but not as deep of a blue as if you used a blue led bulb), and the red areas should stand out more.
Look at this thread for what the white bulbs would look like:
Pics of white LEDs in stock cluster ,
...but yes the xHP5 you are asking about should work fine.
Post up pics when you're done
zfastss is offline   Reply With Quote
Old 10-14-2012, 01:10 PM   #225
KJZ28's Avatar
Quote:
Originally Posted by WS6 What View Post
how did you get that to stay in the holder. I have tried to push the pins tighter, but the led i have keeps falling out.
Bending the pins tighter was all I had to do. Just make sure you bend them from as close to the base as possible.
KJZ28 is offline   Reply With Quote
Old 11-24-2012, 07:52 AM   #226
Hey guys, im new to this forum... but I have a '96 z28 and I recently ordered replacement LED bulbs. In my cars owner manual, and on superbrightleds.com there is a listing for a dome light using the bulb number 906. I ordered this, only to find out what I would call the dome light they refer to as a "trunk/cargo" area using the bulb number 562. Now that i have the 906 bulb for a "dome light", can anybody tell me where this is used?
hambler is offline   Reply With Quote
Old 11-24-2012, 09:08 AM   #227
nightmarechevy's Avatar
On the 98+ they are in the rear view mirror. Should be the same on yours.
nightmarechevy is offline   Reply With Quote
Old 11-26-2012, 11:04 PM   #228
sjsingle1's Avatar
Old 06-24-2013, 03:30 PM   #229
LS1SSZ28's Avatar
Just received an Amazon gift card and dont really need anything that will be covered by the card, then i thought about these bulbs.
Does anyone know if these LEDs specifically the ones that go in the guage cluster are available on there?
LS1SSZ28 is offline   Reply With Quote
Old 06-25-2013, 07:54 AM   #230
Ls1CamaroGuy87's Avatar
Did you try a search? lol they are all over the internet. They are 194 base.
Ls1CamaroGuy87 is offline   Reply With Quote
Old 06-25-2013, 07:58 AM   #231
LS1SSZ28's Avatar
Yes I always resort to searching before asking, but it appears or from what i am seeing they either dont have them...kinda hard to think judging by what they do have.
or They are using a different naming system or something because they have tons of LEDs for automotive but not really seeing these ones...but again im not an expert on LED bulbs so idk. Would rather get them from Amazon if possible so i could just use this gift card that i dont have a use for.
Old 02-27-2017, 09:15 AM   #232
when replacing the bulbs in the cluster with LED, should one get red/yellow ones, or white?
ShovelMan is offline   Reply With Quote
Old 02-27-2017, 12:33 PM   #233
Quote:
Most normally go with red, white or blue. I went with blue. For the signals I put blue ones not knowing so probably be best to go with a different color. Also get ones that are 360 degree for most covered.
Eiyse98ls1 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Correct LED interior lights? JTtransAM Appearance & Detailing 5 04-15-2015 03:14 PM
Switching to LED's, are these right? sheikss Appearance & Detailing 3 03-13-2011 09:51 PM
Rear view mirror/map light (to LED) replacement issue cpo Appearance & Detailing 11 08-08-2010 11:11 PM
LED'S in a 00 bird. ?????'s WS9 Formula Appearance & Detailing 3 05-08-2010 08:01 PM
Found Cool New LED Tailight Bulb JasonWW Appearance & Detailing 35 10-15-2007 11:55 PM
Tags
1996, 74xhp3, backup, brighter, bulbs, change, led, light, ls1, mirror, pc74, rear, signal, silverstar, trans, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
