Bulb to LED List - Page 3 - LS1TECH
Bulb to LED List
Thread Tools Search this Thread
Old 02-03-2010, 01:14 PM   #41
ec_nova's Avatar
just ordered a complete interior set and some kickass reverse LED's ( i have 5% tint need all the light possible lol) will post pics when it's all installed
this is the reverse LED I will be using
ec_nova is offline   Reply With Quote
Old 02-03-2010, 01:19 PM   #42
omarrakeen's Avatar
Quote:
Originally Posted by dhowdy View Post
I believe you need two 3mm LEDs for the odometer and ten for the monsoon head unit as well (need resistors too). Only thing I couldn't find was how to change the color of the display on the monsoon HU. Any thoughts?
*edit* While I'm posting about lights...which ones do I need to replace the side markers? I vht'ed them a little dark and am looking for something brighter. Thanks.
what about the guages?? mine are getting dark and sometimes they wont lit..is it easy to replace and how does it look ? my head unit came LEDed with blue led it looks pretty nice..
omarrakeen is offline   Reply With Quote
Old 02-03-2010, 01:32 PM   #43
jdoyle's Avatar
can anyone PM me a link of where they got the dome light LED for their '99 car?
jdoyle is offline   Reply With Quote
Old 02-04-2010, 12:34 AM   #44
stealth355tpi's Avatar
here is hcool white in a camaro cluster, only thing not done yet is the steering wheel controls. sorry i couldnt get a clear pic.
stealth355tpi is offline   Reply With Quote
Old 02-04-2010, 12:47 AM   #45
t/afrom504's Avatar
What LEDs i need for the lights in the backseat, I have a vert if that helps?
t/afrom504 is offline   Reply With Quote
Old 02-04-2010, 03:10 AM   #46
fbodyrs96's Avatar
Quote:
RL4410-xHP9 Rigid loop Festoon bulb
fbodyrs96 is offline   Reply With Quote
Old 02-12-2010, 05:27 PM   #47
jdoyle's Avatar
Quote:
RL4410-xHP9 Rigid Loop Festoon bulb
Does anyone know if this bulb will work for the dome light of a '99 car?
Thanks,
jdoyle
Old 02-17-2010, 06:10 PM   #48
Sykokilla's Avatar
Thanks,
jdoyle
Yea man it will work. I got mine in and I have a 98'. works great.
Sykokilla is offline   Reply With Quote
Old 02-18-2010, 02:40 PM   #49
SuperDave479's Avatar
Anyone know what to use for a license plate LED? I just want to replace the existing bulb with a LED one to give it a whiter light, not necessarily brighter.
That's the main thing for now but I'm also curious about which ones I should use for my reverse lights. I want to do the same thing there.
SuperDave479 is offline   Reply With Quote
Old 02-18-2010, 03:41 PM   #50
fbodyrs96's Avatar
#194 for the license plate.
Old 02-18-2010, 03:55 PM   #51
Anyone know which bulbs would be the best fit for the rear tail lights, and reverse light? I tinted my tail lights, and need a little more output, since they got just a little too dark. Also, should I go with red or clear color? Thanks.
Black_Z28 is offline   Reply With Quote
Old 02-18-2010, 05:33 PM   #52
Mike@ZMS's Avatar
I vote Sticky!!!
Mike@ZMS is offline   Reply With Quote
Old 02-18-2010, 05:47 PM   #53
blackodium's Avatar
has anyone used the ones that look like that but in red for the tail lights?
blackodium is offline   Reply With Quote
Old 02-18-2010, 07:29 PM   #54
Thanks, but I'm trying to figure out the LED equivalent at around the same brightness. I selected that on the superbrightleds site but it gives me like 6 choices.
Btw, love your car. One of my favorites on the site.
Old 02-19-2010, 12:23 PM   #55
ginop524's Avatar
does anyone know if its possible to change the bulbs that illunimate the window switches... and if their is a bulb how do you remove the old ones, i cant get them out for my life.. do you have to cut and splice if possible at all. thanks
ginop524 is offline   Reply With Quote
Old 02-20-2010, 07:35 AM   #56
fbodyrs96's Avatar
Quote:
bulb #74 pull out with pilers
Old 02-20-2010, 07:37 AM   #57
fbodyrs96's Avatar
the more LEDs the brighter, but the hole is really small, may not have much choice on which led will fit.
Old 02-22-2010, 04:18 PM   #58
Irish350's Avatar
any reason why the door lights wouldnt work but the other courtesy lights do?
maybe the lights need to be pushed in deceptively far (into the housing?)
ive got nice white lights now, but the doors are still dark.
Irish350 is offline   Reply With Quote
Old 02-23-2010, 02:03 AM   #59
offroadfury6's Avatar
so 5 of the SMD5 wont work for the cluster?
offroadfury6 is offline   Reply With Quote
Old 02-23-2010, 02:58 AM   #60
ZexGX's Avatar
I have used tape to tightly sandwich the old bulb in, then the tape grips the bulb and provides a handle to pull the old bulb out by hand without destroying it.
The courtesy lights are on a different circuit than the door lights. The door lights are wired to come on when the Parking lights and Headlights turn on. Another possibility is you might need to pull the LED and flip it 180 degrees to reverse the polarity. The door lights also have a red plastic embedded in the female end of the bayonet system, so even if you put a white LED in, only red light will shine through until you take a Dremel and drill out the red material
ZexGX is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Correct LED interior lights? JTtransAM Appearance & Detailing 5 04-15-2015 03:14 PM
Switching to LED's, are these right? sheikss Appearance & Detailing 3 03-13-2011 09:51 PM
Rear view mirror/map light (to LED) replacement issue cpo Appearance & Detailing 11 08-08-2010 11:11 PM
LED'S in a 00 bird. ?????'s WS9 Formula Appearance & Detailing 3 05-08-2010 08:01 PM
Found Cool New LED Tailight Bulb JasonWW Appearance & Detailing 35 10-15-2007 11:55 PM
Tags
1996, 74xhp3, backup, brighter, bulbs, change, led, light, ls1, mirror, pc74, rear, signal, silverstar, trans, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
