Window Problem!!
Window Problem!!
Experienced window panel-ist needed. My driver side window on my 98' T/A has come off the track. I can find 3 screws to remove and lift up the panel from the hooks. However, there is one damn spot toward the elbow that acts as if it is bolted in. I can't find a way to remove this item. Any ideas???
There's 4 screws that you must remove to take off the panel. They are pointed out by the arrows in the pic. The arrow that points near the door handle the screw is actually behind those panels so you must remove them to get to the screw. Hope this helps
Will
Will
Will
Will
