faded black molding between windshield and hood- MIRACLE CURE
Old 10-11-2009, 04:05 PM
crimson_bird's Avatar
Default faded black molding between windshield and hood
if yor car is like the three 4th gen. f-body's outside my house, then the black area between the windshild and the hood is probably pretty faded and giving your car a somewhat worn look, which i personally don't like.
So, here is the cure:
materials needed
-Bondo restore black - around $10
-masking tape
-small foam brush
this is always something that has irritated me after washing the car and then having to look at that faded plastic. so, i was in wal-marts auto section going through some things and came across this stuff. i bought it to do the t-tops, but i ended up doing this first. i was sceptical, but it worked so good i'll be using it for all of the black trim around the windows, the t-tops, and anywhere else i can.
BEFORE:
as you can see, you will need to tape off the entire area, so as not to get it on the pained surfaces and keep it off of the glass. also, check the pics to see the foam brush i used. this did not come with the kit. the kit came with a much larger foam pad that is too big to use effectively, so i'd recommend getting one. you should be able to find it in the paint or arts/crafts department of stores like walmart or michaels. luckily i had it at the house.
i just drizzled some on the surface and then spread it around. once you start using it you'll find what works best for you.
-here are some progressive pictures so you can get a good idea of before and after.
And the finished product
i pulled the car out of the garage so you can get a good look.
It may not seem like a big thing, but once you do it you'll love the difference. Trust me
Old 10-11-2009, 04:31 PM
1979rs/z28's Avatar
That looks nice. Ive been using back to black but it never shines it out perfectly. Whats the bondo stuff like a paint? Hows it holding up?
kenp's Avatar
Very Nice.
Old 10-11-2009, 04:34 PM
JunkyardZ's Avatar
looks good. but I would recommend taking the plastic piece off the car and throwing a coat or 2 of black paint on it and then clearcoating it. Makes it look brand new and it last and last.
Old 10-11-2009, 04:53 PM
yea its pretty much like paint. just spread and let dry. i really like it because instead of a glossy, wet kind of black, it just gives it a very NEW look. and i actually just did it, so im not sure how it'll hold. but the box says "up to 6 months" so we'll how it goes.
Originally Posted by kenp
Very Nice.
gracias
depending on how long this stuff holds up, i may end up doing that . but for now it looks great, and it was a pretty quick job.
Old 10-11-2009, 05:20 PM
ben77's Avatar
Great find! I'm gonna have to try some out now.
Old 10-11-2009, 05:32 PM
DBurgLT1's Avatar
Looks really good
Old 10-11-2009, 05:52 PM
evilZO6's Avatar
black shoe polish does the same thing but its easier and cheaper. It looks really good!!! Its true, you don't notice things like this until you do them!
Old 10-11-2009, 06:09 PM
x2jesse1x's Avatar
Painted mine with Saten Krylon Fusion thats made for plastic
Old 10-11-2009, 06:36 PM
DaddySS's Avatar
Nice find. I just keep mine coated with UV protetcant and so far so good.
Old 10-11-2009, 07:13 PM
dragcamaro's Avatar
anybody tried peanut butter, ive heard stories about it but never tried it
Old 10-11-2009, 07:38 PM
DCC!!'s Avatar
wtf peanut butter? like rub it on???
look great btw! keep us up on how long it last and how long it take to fade
i wana do it but not if it only last like a month lol
Old 10-11-2009, 07:42 PM
this isnt my dd so it doesn't see really any bad weather, so it should last for quite a while. but if it starts to fade i'll definitely let everyone know not to use it
Old 10-11-2009, 07:46 PM
DCC!!'s Avatar
ok thanks! bc it it does fade thrn i will just take it off and paint it but if not then go cheapo lol
Old 10-11-2009, 08:06 PM
stroked383HSR's Avatar
yep! looks great!!...your just like me....im **** about stuff like that and ive been wondering on how to get it to look new.....
so how hard is it the remove that peice? whats the steps for doing that?
Old 10-11-2009, 08:12 PM
AZ2ENVY's Avatar
Looks great ! .... Heads off to Wal Mart to get some
jattgunman's Avatar
Ive been using this stuff for a while and it is for sure alot better than mothers back to black. This stuff usually last about 8 months,Make sure not to use it on smooth surfaces
Old 10-11-2009, 08:31 PM
AZ2ENVY's Avatar
How much did this cost btw ?
Old 10-11-2009, 08:36 PM
pheonix_rising's Avatar
Stoner's Trim shine works really nice as well. Real happy with the results. Spray on and watch it work.
Old 10-11-2009, 08:50 PM
bballr4567's Avatar
Mine looks pretty pitiful so this is a great idea. I was wondering what to do about it!
Quick Reply: faded black molding between windshield and hood- MIRACLE CURE
