Removing Water Spots From Glass???
What do you guys use to remove BAD water spots from glass? We are detailing the white WS6 for a show this weekend and under the lights in the garage you can see it has TERRIBLE water spots on the glass...and nothing I have tried so far has touched them (clay bar, Invisible Glass or Zaino polish). What do you guys suggest?
I use Zanio Z-12 with my porter cable Lake country white ccs pad or wool pad. If that does not work then I would use Meguires M04 heavy cut cleaner with a wool pad. Lake country also make glass cut pad & polishing pads.
If you have ZPC-fusion might try that.
I would finish with Z-12.
Good luck!
Good luck!
i've done this and it works wonders.
here it is: https://ls1tech.com/forums/appearanc...-write-up.html
BE CAREFUL with the steel wool and glass stove top cleaner. I did mine this summer and it looks great except for when the sun hits it just right i notice slight swirls that are tiny and nobody notices but me, but it still manages to annoy the hell out of me
I have never had to use anything more than claybar either but the spots on this car were the worst I have ever seen. It almost seemed like industrial fallout or something...it really was that bad. BUT the steel wool and Glass Stove Top cleaner worked wonders and its about 99% off now!
Thanks for the idea guys!
Good luck!
Good luck!
Z-12 on a PC on an LC orange should cut through it. Or if that doesn't, try an LC PFW.
Yeah. Also make sure you keep the window wiped or washed off after you have scrubbed the spots off. If you leave it, be prepared to do it again. Also, get it off all the trim and linings, it will stay.
