Custom C5 Fixed Headlights
After severeal years of research and 5 months of development, I finally built a set of headlights I can be proud of. They are a dual-projector setup mounted on one-off rienforced Aluminum Frames. The Shroud is thermoformed ABS on a mold i designed and the lens is thermformed impact-resistant UV treeated Plastic (similar to lexan but easier to form)
in shop shots:
daytime shots:
Nighttime (good stuff)
Range shot (from about 20' off the ground)
Tripod at 150' distance:
Sharp Projector cutoff pattern:
in shop shots:
daytime shots:
Copy & Paste Moderator
I was wondering when you'd post this here. I've been following your thread on HID Planet: http://www.hidplanet.com/forums/viewtopic.php?t=51691
that'll work. it came out great. post up pics when you paint the lenses, I'm sure it'll look factory once it's finished. and are you planning on making a kit for this and sharing ur mold ? with the feedback your getting it doesn't sound like a bad idea to me.
