foglights without headlights?
well i've looked on here to see how i could run fog lights without my headlights up(with stock switch) couldn't find anything i'm new to the t/a's, but if i don't get a post I'll prob just start running down wires to see how i can do this lol just wanted to follow some instructions before i spent a lot of time searching for something simple
All I have to do is turn to park lights and leave my fog switch on all the time so they always come on. If you turn all the way to the headlights then back to park the doors stay up but only fog and parks will be on
mine come on with running lights but headlights are up. I'm rewiring this so i can run foglights with the bat wings up lol also i'm rewiring so when i hit my lock and unlock on keyless they don't pop up either
If it fogs don't come on when you put on the Parking Lamps it's because the motors/gears need replacing.
Do your lights grind? If so, then replace the gears, and you shouldn't have this problem, but then again, you can also rewire them or ground them (if I recall correctly).
If your headlights are opening with your keyless entry you have a problem. As suggested probably the gears for the headlights. If properly working you should be able to just turn your light switch to the parking light setting and have your fog lights on without the headlight opening.
