Fuel Rail Cover Questions
I swapped a 5.3 into my v6 camaro a while ago, and have since cammed it and put an ls6 intake on it. Since I have the truck coil packs and the ls6 intake, can I use FRCs?
Whats the difference between the black and red ones?
Why do some have 2 cuts in them and others only 1?
The red ones are from a Z06 and the black ones from a regular LS1 Vette.
The ones with 2 holes are for cars with a return fuel line and the ones with 1 hole does not have a return line. Most F-bodies (unless modified) will need the ones with 2 holes.
no difference other than the color and the one verses two holes......and just to add i put them on my 2002 ls1 which has the two lines...i got the z06 red ones with only one hole and just ran a new return line (made it longer) and put both lines in the one hole...worked great!!!!
you are correct....the line runs up to a small plastic evap piece then into the TB or intake i cant remember....i just wasnt going to get into all that, i was just stating that i had two lines, and still used the FR cover that had one by extending the length of the front line......
sorry for the off topic discussion...........lol
