Gauges Center Vents
Gauges Center Vents
Well I have had this mod done for a while. From the pics I have posted you all know I had a triple pillar pod. Well I kept hitting my damn head on it getting in and out of my car. I also wanted a cleaner look to my car. I was out and about and decided to snap a couple of pics. On a side note I rashed my rims tonight cause I wasnt being careful enough pulling up to the curb. I want to kick myself in the nuts right now.
PS It just rained reason the rims are so dirty
Yeah, im not to worried about the wheel. Its not the first time I have refinished them. As far as the vents go. I went ahead and ordered vent adapters from a site sponsor that sells them. (cant remember atm) A 2 5/8 gauge will fit perfect in there. But Autometer does not make the ES Series in that size. I want to make some adapters myself that are more angled and kind of point the gauges in the direction of the driver like a 3000GT
If you could find the sponsor that sells the adapters, and post in here (or PM me) it'd be much appreciated.
Im headed out the door and Im going to be busy the next couple of days. Ill see if I can find the link later tonight though. No, its really not that bad. I can still see my gauges at a glance. I like them a million times better there rather then in my triple pillar pod. I kept hitting my damn head..haha
No they are chrome.
Yes she does. I only drive her during the summer. Even then I ride my 07 R1 more then I drive my car.
Split Bumper? If you are talking about how the front and rest of the car look like two different colors of silver well they are not. When you are standing there looking at the car you can in no way tell the difference Unless you see it at a certain angle. I have no clue why it appears that way in pictures and at certain angles. Guy at the body shop said it has to do with the difference between the materials painted and happens more with certain colors on older factory paints. At any rate if you are talking about the rear bumper that was cracked when I got the car. Well I have a new bumper on the way.
there's a thread out there with a part number for a pvc coupler that works perfectly for the 2 5/8 (iirc) gauges to fit in the TA AC vents. I ended up going that route since they cost about 2-3 bucks each. Forgive me for the wires and the glare but you get the picture. I was yanking all of the nitrous wiring and other wiring i didnt need anymore and it kind of accumulated in the passenger foot cab for the time being
I really like how the gauges sit flush w/ the adapters instead of popping out. Different preference you might want to consider if you're looking to do gauges in the vents (could differ between gauge brands too, others might not be able to sit as flush). Oh and no thats not my actual A/F ratio. The gauge is currently unhooked as i had to make some changes to my exhaust setup and at the time of the pic the A/F gauge reads a number before displaying "AIR". Soon enough though I'll get everything hooked up
[IMG]http://i869.photobucket.com/albums/ab256/transamwst/2.jpg[/IMG
[IMG]http://i869.photobucket.com/albums/ab256/transamwst/5.jpg[/IMG
[IMG]http://i869.photobucket.com/albums/ab256/transamwst/4.jpg[/IMG
[IMG]http://i869.photobucket.com/albums/ab256/transamwst/3.jpg[/IMG
(Wideband Left Bank)(Fuel Gague)(Wideband Right Bank)
Then I am redoing my dash and adding a custom cluster. It will be Speedo Center, Oil Pressure and Volts Left Side of speedo. Oil Temp and Water Temp Right side of Speedo
Ninjai Edit: Just looked at my pics, the gauges dont stick as far out as they look in the pics. Its a trick of shadow and lighting
