Sponsored by: DashLynx
Brake vents on a Ta
Old 06-06-2010, 04:24 PM
jaysan's Avatar
Default Brake vents on a Ta
Is it possible to use the side vents as brake vents ?
Old 06-06-2010, 05:12 PM
Spd-Kilz's Avatar
To provide cool air? No.
To dissipate heat? Doubtful.
Old 06-06-2010, 07:33 PM
CHRIZ28's Avatar
What about the ones under the blinker in the nose? The side vents in the fender I don't think would do anything.
Chris
Old 06-06-2010, 07:38 PM
therealcreeper's Avatar
like so?
https://ls1tech.com/forums/suspensio...s-install.html
I don't think that design is very efficient at all, but it's what you were talking about. Anything is possible with some fabrication. Search around on FRRAX, there's some pretty decent setups that people have pieced together.
Old 06-06-2010, 08:26 PM
jaysan's Avatar
I was thinking like a cut in the wheel well and some type of chute(like SLP CAI) that will direct the hot air out to the vents .
Old 06-06-2010, 08:44 PM
I'd rather route cool air onto my brakes than just create a small passageway for it to escape through that vents right onto my paint, just my initial thought
Old 06-06-2010, 09:23 PM
jaysan's Avatar
Will the hot air cause the paint to flake and chip ?
Old 06-06-2010, 10:22 PM
no, by the time the air gets a few inches away it's barely even warm, especially if the car is moving
I suppose it would be kind of cool if those vents served a purpose, but if you're looking for performance you'd have better luck making ducts that go from the slots below the DRL's or starting from the air dam, than making heat extractors for the brakes.
Quick Reply: Brake vents on a Ta
