need help... fogs won't work.
just like it says the fogs aren't working. i've checked the relay, the connectors, the bulbs, the fuses, the switch, wires leading to, nothing i've done everything in threads and nothing. all the other lights are working fine.
Also, did you check the voltage when your fogs are on? My relay sounded like it was working, but when I checked the voltage across the leads, it wasn't passing voltage. It lit the led in the fog switch too, which threw me off for a little bit too. I'd just start at the leads for the bulbs, and work your way back.
