How to mount Raptor shift light in defrost vent
Old 06-27-2010, 12:14 PM
2kblackgtp's Avatar
Default How to mount Raptor shift light in defrost vent
Hey, I have a raptor shift light, and went to install it the other day. I ended up cutting out the slits in the vent, epoxying it all, and drilling a 3/4 hole for the shift light. That didnt work out too well and it looks liek crap, I wanted to see and know what other people did to mount there's, so please post up if you have one in the defrost vent. I searched and there was little information i found, best thing i found was the camaro interior thread which wasnt a ton of help. Thanks
Old 06-27-2010, 04:29 PM
bj350hp's Avatar
a rubber grommet would work in the hole.
http://cableorganizer.com/grommet/?s...LAID=261926377
Old 06-27-2010, 04:59 PM
Spd-Kilz's Avatar
I have a Harlan light. So I am not sure if the two are the same size.
My method was to cut out the vent slats until they were almost smooth. It snugged in perfectly.
Old 06-28-2010, 07:44 PM
2kblackgtp's Avatar
hmm, must be a different size then, my vent was about 1 inch when i cut out the slits, and the shift light was 3/4 inch
Old 06-28-2010, 07:56 PM
djfury05's Avatar
the Harlan shift lights are larger than the raptor lights.. you didn't have to cut the defrost vents to get it in there but now that you have the best bet is prolly a rubber grommet like posted above or go to a junkyard and swipe one
Old 06-29-2010, 12:43 AM
bj350hp's Avatar
Here is a Quote from a old thread. This guy used a Valve cover grommet from autozone.
Originally Posted by BriancWS6
I installed my Raptor shift light in the a pillar back in 05. I took the plastic tube that runs to the defroster vent all the way out. A valve cover gromment from Auto Zone works perfect to install it. The brand name is Spectre. Here's a couple old cell phone pics.
Old 01-26-2013, 07:53 AM
ryangtp89's Avatar
Now if i do this can i still install a single gauge on the a pillar for my wideband, will they both fit ?
Old 07-15-2013, 04:15 PM
orthopod's Avatar
Did anyone ever find out if the autometer single gauge pod and the raptor shift light in the ac vent combo provides good visibility for both?
Quick Reply: How to mount Raptor shift light in defrost vent
