Upper Dash Cracked
Upper Dash Cracked
When I bought the car it was perfect. Now after 1 year of florida sunshine my upper dash or front dash or whatever you want to call it is cracked badly.
I had looked in this section of the forum for a little bit and I'm suprised I don't see a lot of other posts about it or at least one. It seems like mo0st camaros in florida do not have a dash or have one cracked.
Does any one know where I can get a replacement. I dont want the cover or the top cap. I just want a replacement. Any idea how much thery run? Links would be appreciated. thanks in advance.
Mine cracked too.. I tried to fix it but the repair can't hold up to the heat. I made a post in the parts wanted section, someone had a few for around $200 I think. I know, crazy expensive.
If you click my name, then click view profile>statistics>view threads.. you might be able to find my old thread and find the guy that had a few
Thanks I appreciate it. This florida weather is too rough on them. Almost every single one I see is pretty rough. It really suprises me no company out there makes them. They have the top cap which is basically a molding of it you place on top but I just don't wana do that. I apprecaite the help ill definetly check it out.
If anyone else has an idea I appreciate any suggestions you have.
how bad is it cracked... take a pic and post up, if you go in the "hall of fame" sticky up top then find the write up on how to fix the dash pad, if you dont want to go that route then send that **** to me so i can try to fix it (after you buy a new one i just wanna see if i can do it)
