tinted taillights too dark.... repaint or LED lights?
I tinted my taillights with VHT, and at night, you can see the lights perfectly fine. However, during the day, its hard to see the lights when i have the flasher on. Will upgrading to LED lights help, or am I better off repainting the lights?
how many coats did you use???
i thought i did mine too dark as well but even in direct sunlight you can stll see the brake lights perfectly.... i did 4 coats of VHT and 4 coats of clear
depends on what you like... do you like how they look now, or would you like the tint to be a lighter shade?
if you like how dark they are, add LED's and that will solve your problem, and you'll still have the dark black look. If you'd be okay with having a lighter tint, than sand them down and add less VHT.
depending on what kind of car you have thats an expensive compromise. Id sand and respray so the tint is where you want it, and if you want more light output / faster signal, grab some LEDs
