painted some of the headlight brackets.
Old 07-05-2010, 08:54 PM
formulafast's Avatar
Default painted some of the headlight brackets.
To clean up the engine bay a little decided to paint some rusted parts black. tell me what you think. (not finished yet just gaging intrest)
Before
after
Old 07-05-2010, 09:05 PM
Gordo78's Avatar
All of that stuff comes out with a few bolts per piece. You should take them off instead of just spraying them and masking with a little bit of tape. That overspray is terrible.
Old 07-05-2010, 09:14 PM
LS1RedZ's Avatar
Looks alot better. I just did this to my car. I took everything off the front of the car and painted it. Its really easy to pull everything off. Definitely cleans it up.
Old 07-06-2010, 12:22 AM
9WhiteCamaro9's Avatar
^ what gordo says i took half of all that stuff off and did an extensive clean up job under my hood and its not hard to take that stuff out and/or put it back in either but it does look better
Old 07-06-2010, 11:11 AM
NightWindDriftr's Avatar
Great idea but you should have taken the piece out. It's far less effort than cleaning up the overspray.
Old 07-06-2010, 11:21 AM
thank you. I thought of that after I sprayed it. I was just doing on bracket and seeing what it looked like but my friend wanted to keep spraying mine and his so kept doing it. Im going to take it apart next weekend and work on it for a few weeks since I can do that. =) and also repaint some of the white car frame and also the ttop metal bar since that is fading too.
Old 07-06-2010, 11:32 AM
this is after the tape is taken off.
Old 07-06-2010, 11:42 AM
collier341's Avatar
I have a feeling the next thread started by Op will be...
"Fixed horrible overspray and repainted brackets correctly after paint flaked due to no prep"
You had the right idea man, you just shouldn't have been lazy.
Old 07-06-2010, 12:47 PM
its my first time doing this. I did it right. I sanded the brackets cleaned them off then painted them. I didnt primer them I wont lie. but when I take them off Im gonna prime it and all that fun stuff.
Old 07-06-2010, 01:16 PM
MjMaro's Avatar
You just said you did it the right way and defended your point by saying there was more you could've done. It looks ok, but will be 1000X better when you take them out and actually do them the RIGHT way. Your ambition is good, just unrefined.
Quick Reply: painted some of the headlight brackets.
