3 guage pillar mod
3 guage pillar mod
I have the 3 guage pillar mod. Keep in mind I am not extacly brightest bulb in the box, but not exaclty burnout either. Where do i run these wires to? I need to tap into something to get these guages working i have a temp guage volt guage and a oil guage. Im sure this should not to be soo complicated but hey thats my style. if anyone knows which wires or where to splice into them or any info would be helpful. Also i did try to find some info on eearch but couldnt
thanks
thanks
1 Post
i ran all my wires to get em to light up and work and all that to the fuse box to the left of the dash. but to get em to actually work and read out what you need, i cant help you there cause i have diff gauges in mine so sorry i couldnt be a complete help
I think my autometer gauges required 2 power and 2 ground wires each so I just ran 1 wire from the ign spot in the fuse panel up to the gauge pod and tied all of the gauges into it. I also just ran 1 ground wire from a spot under the steering column to the pod and tied the gauges into that. It was easier than running a bunch of wires. Then its just the sender wires to hook up. The gauges should come with schematics that will help alot.
