Emblem pros switch plate, solution for SLP HI/LOW fan wiring
After searching a bunch of threads over the last year or so, nobody seems to be able to give a clear wiring instruction for a DPDT switch to work the SLP #63011 fan switch setup. So, I decided this could not be that hard to figure out? Simply put, it was a breeze! I tested for power on the original switch and basically mirrored the connections on the emblem pros DPDT switch and voila! It works perfect, center position is the OEM setting that the PCM controls, bottom position is for single fan (LOW), and top position is for dual fans (HIGH). Wired & heat shrinked everything for a nice factory look and installed it back into my console ashtray section (96 LT1, 6spd). Here are some pics !
