Leather Interior
Leather Interior
Does anyone know how possible/how realistic it is to get Heated Leather Seats into a 99 SS? I currently have cloth interior and have been looking at leather out of other SS's.. but I would LOVE to have heated leathers-- Any idea on costs? Who to call? PLEASE HELP!!!!
Thanks in Advance.
-Garrett
Thanks in Advance.
-Garrett
Absolutely!
Go here: Firehawk Dual Heated Seats
to see my Firehawk setup.
It comes with lighted LED toggle switches and they're toasty!!!
The set is available from Fast Toys.
I've had mine for a year now and they're awesome.
Had mine installed professionally at an auto interior shop.
Not easy; you need someone to remove seats and leather covers, then you need that same person to understand electrical wiring. They're tapped into the power seats and then under dash into fusebox.
Mine switches are in my center console and look STOCK
goto www.autoleather.com and check out their custom leather, and seat warmers, you can check out pics of my leather done by them at www.ssgraphix.com/car/pictures.php
-Steve
-Steve
You can do the leather yourself. I did mine myself. Just take your time and you'll be okay. Taking the seats out of the car is painless. Taking the top half of the front seat covers off is easy. Taking the bottom of the seat covers off is a PITA! But very doable. Our cars have some industrial velcro attached to the foam cushions; no hog rings, so once you get the seat cover lined up smooth it down and you're all set. The back buckets have small rings that hold the material to the seat frame. Those can be removed and attached again with needle nose pliers. The one piece seat back is cake, you just have to remove the seat belt brackets and the swivel brackets at the bottom corners to get the seat back out.
As far as wiring the heated seats up, I'm assuming it is pretty simple. You'll have a power, ground, and then a switch you can mount anywhere. If you are tapping into the power seat harness, you shouldn't have to mess with the fuse box at all. Only problem is you have to make sure you turn the heated seats off before you leave the car. I'm sure you've noticed the power seats have 'power' even after you turn the car off.
Best thing you can is pull the seats out of your car (very easy) and take a look at 'em, you'll likely be intimidated at first, but the more you familiarize yourself with them the more confident you will be. Doing it yourself sure beats paying some upholstry shop 300-400 bucks when you can do it yourself over a weekend.
Only problem???????????????
Guess what; I have NO problem. Because the professional wired into my fuse box, I have the safety of knowing that in case I DO forget to turn off either one of the seats, they will be off as soon as my ignition is off. There is zero chance in my car of ever coming out and finding my seats on fire
'Ya gets whats ya pays for...
Originally Posted by Dawg One
PRECISELY why you don't want to be cheap and take the rigged approach. Me? I PAID a PROFESSIONAL the low fee of $200 and it took HIM all morning and into the afternoon to do it properly.
I did mine a few months ago when they had a gp on them. It is alot easier than people are saying. I did mine in under 4 hours taking my time while vaccuming and cleaning the carpet. I also conditioned the leather when I was done. I started on the back buckets just in case I messed something up. Seeing those hog rings, I thought the whole car was like that and thought it would take me forever. The buckets are the hardest to do. After the buckets it takes no time at all.
I will be putting in seat heaters from autoleathers really soon.
Good luck on the install.
i've got a group purchase with another leather seat company on two other forums. I've email Tony and he talked with the company and hopefully it will be posted on here. if you like to get in on it or know someone who does email or pm me.
thanks,
thomas...
thanks,
thomas...
Originally Posted by onehardmaro
The wiring is probably easier than covering the seats. I would rather do it myself keep my $200 and brag that i did it.
MYBLKSS: I don't have any interior pics yet, and my car is covered in about 6in of snow right now.
I really don't think a PROFESSIONAL could have done a better job covering my seats than me simply because it doesn't take a professional to do it (there is nothing technical about it, nothing specialized) and they wouldn't care about my car the way I do. I needed everything to be perfect, line up perfectly and fit perfectly.
My only complaint is with the seatcovers themselves. They have the same pattern as the stock, but the material they used (which is supposedly "above and beyond what GM uses") feels cheap. It has a texture to it as opposed to feeling smooth like my stock covers. It almost feels like pigskin. On my leather seats however, only the inserts are leather, everything else is vinyl. But even the real leather just doesn't feel right. Not a very high quality product. Got mine from leatherseats.com
Oh by the way, in many cases you'll find that this so called "Professional" has nothing more than a high school diploma or GED. Surely he isn't a certified 'Leather Seat Cover Installer'.
