Anybody w/ FRC's and Metco breather?
Re: Anybody w/ FRC's and Metco breather?
NO I not have FRC but I do have the Breather and if you don't have a STB use the stock angled oil piece and screw the metco metal piece on top then the breather should work good.
Got the 'vette FRC's installed w/ some effort but worth the effort. The only concern I have is when I put the Metco breather on it snugs down pretty tight against the FRC. It seems to seal and is hard to pull out as before, but I do see some contorsion on the bottom due to the pressure caused from the FRC. Does anybody have this setup? Have you had any problems with the breather popping off. Don't want oil spraying everywhere on a just detailed motor.
BTW, without this forum for referance I would have never tried this mod. Thanks to all that have posted in the past!!!!!!!!!
Good Hunting.
Randy
Good Hunting.
Randy
I broke that when I replaced it with the Metco piece... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> The sob lost that war. I have a stb anyways. I took it out for a spin and seems ok. I thought somebody would have this setup??? Pretty common mods.
