Sponsored by: DashLynx
just received my 1969 .....
Old 12-23-2002, 06:02 PM
RICHS_Z28's Avatar
Default just received my 1969 .....
Just received my 69 OER Z/28 emblems. i bought them off of ebay for $20.00 each. luckily i had them shipped to my work or else i would have to get them at the post office. anyways i was wondering how to get the studs off? and also what is best to use to have them stick on the fender? and also if anybody else has done these did you put one on the rear also. i forgot about that one. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
thanks for any info..
Old 12-23-2002, 06:22 PM
ratio411's Avatar
Default Re: just received my 1969 .....
I put the 70.5-74 emblems on mine. They are very similar to what you have there. They look just like your avitar.
I used the studs and drilled holes to mount mine. If you remove the studs, use a hacksaw, then finish it off with a dremel. Work carefully, the emblems are not fragile, but they aren't tough either.
The best stick'em to use is 3M emblem tape. It is pretty much just 2 sided tape and you get it from an automotive paint supply house.
That's about it. Oh, I didn't put one on the rear. I think it looks much cleaner with nothing back there.
Dave
Old 12-24-2002, 01:32 PM
Greg99LS1's Avatar
I used the studs for the grille emblem, cut the studs off with a Dremel tool and used the 3M emblem tape for the fenders, and used the '72-'73 foil emblem (sticker - $3!) for the hatch lid because I didn't want to try and mangle a fender emblem to match the curvature of the hatch....
Using the '69 emblems, what would look the best (to me) for the rear would be to have the C A M A R O letters filled and mount the Z/28 right under the hatch lock cylinder, just like it was done on a 1969 Z/28. Would be very sharp looking!
