Center Console top , re-designed to be more modern . Lots of pics - Page 3 - LS1TECH
Thread Tools Search this Thread
Old 11-10-2010, 09:09 PM   #41
1FASTZ28's Avatar
very interested in this
1FASTZ28 is offline   Reply With Quote
Old 11-10-2010, 10:11 PM   #42
Irish350's Avatar
Quote:
Originally Posted by LT4vert View Post
For both the dynatron and the 3m glaze if I remember right I had about $45 between the 2 . I'll see if I still have the reciepts at home when I get there this weekend . As far as where to buy , I google them and whoever is the cheapest is where I buy it . Check your local automotive paint supply shops locally to, no of local shops had this stuff in stock . Yea you can use it to repair urethane bumpers , thats what both these products are originally intented for .
Sean , I think I would stick to fiberglassing on larger scale projects or clay molds and heat forming ABS or polypropylene on a vacum table . Both the dynatron and the 3m arent available in larger mediums than the tubes in the pictures I showed and would be HELLA expensive to buy enough to larger projects . Both are more suited for smaller projects like bezels and such .
Thanks for the compliments . Hopefully I get more done soon .
Im gonna shoot you some pictures when i decide to tackle it, to see if im looking at the right scale... NEVER thought to heat mold anything aside from projector lens covers, but thats another damn good idea thats totally hindered by my garage full of dumb ****. Id like working clay/abs more than glass, assuming I can figure out the table
Quote:
Originally Posted by InsaneAuto86 View Post
Looks very good! I used fiberglass and bondo on my center console. Holding up great so far.
I also need to grab some materials lists from you Matt, cause you 'glass totally different than I do, every update you do has me like aside from the standard forming/sanding/etc
For now im more than content to be lazy and watch you guys do innovative stuff
Irish350 is offline   Reply With Quote
Old 11-11-2010, 01:34 PM   #43
black_99/SS's Avatar
I cant wait to see this thing finished. I cant to start working on my own!
black_99/SS is offline   Reply With Quote
Old 11-11-2010, 03:58 PM   #44
LT4vert's Avatar
Sean- The heatforming is definately a cleaner process , theres just alot less room for error . Just got to be careful using the correct epoxy to bond the plastics . Most epoxies will permently bond ABS together . Polyprolylene , you can only use an epoxy designed for it ( to my knowledge there is only 1 from 3m ) . All other epoxies or adhesive will not permenantly bond low energy plastics like Polypro . I threw polypro in there because most of the interior panels in these cars are made out of polypro . For the vacum table , you can use an old electric range converted or just make a box , and use a shop vac . Search vacum table or vacum forming on youtube and it will give you a better idea .
LT4vert is online now   Reply With Quote
Old 11-19-2010, 06:27 PM   #45
Irish350's Avatar
So the ABS gauge pod that i epoxied onto my factory gauge bezel would be a situation where id need the fancy 3m stuff?
Old 11-19-2010, 09:34 PM   #46
LT4vert's Avatar
After epoxying it to the bezel , yep... I would be using the dynatron to blend and then 3m to finish off any imperfections . Then a good sealer primer , then paint . I would not use just the 3m alone, its meant to be used more as a finishing glaze .
Old 11-19-2010, 11:36 PM   #47
Irish350's Avatar
what if its getting wrapped? just the dynatron, 3m and then adhesive? (probably wont happen, really a complex piece now, just keeping my options open)
hows the console?
Old 11-20-2010, 12:40 AM   #48
KLaBZ28's Avatar
I feel like this is what the center console should have looked like. This is inspiring to mold a console to the radio bezel to get that sweeping down console effect.
KLaBZ28 is offline   Reply With Quote
Old 11-20-2010, 09:16 AM   #49
LT4vert's Avatar
Quote:
hows the console?
If its just getting wrapped, I would jus use the dynatron and sand as smooth . Have fun wrapping that lol .The fb bezel is bitch on its own , and the pods are bitch too . Both together=yikes Im going the extra mile to get a perfectly smooth surface because I think Im gonna try to make mold out of it . Otherwise I wouldnt worry so much as Im wrapping it.
KLaBZ28- Thanks man .
Old 12-18-2010, 12:02 PM   #50
Anymore pics?
TAEnvy is offline   Reply With Quote
Old 12-18-2010, 12:16 PM   #51
9t8z28's Avatar
Quote:
Yes! A sweeping console would really set off the Camaro interior!
9t8z28 is offline   Reply With Quote
Old 12-19-2010, 11:22 PM   #52
Fast T's Avatar
Looks real good.
Fast T is offline   Reply With Quote
Old 12-20-2010, 12:30 AM   #53
Irish350's Avatar
man, you're slackin all over
Old 12-20-2010, 10:40 AM   #54
LT4vert's Avatar
I know right lol . I got caught up enrolling for school and other stuff. I should be back at work on this next month .
Old 12-20-2010, 12:03 PM   #55
SLPHawk300's Avatar
I would like to see somebody tackle covering the ash tray and cup holder over. the ashtray (if you have a short throw shifter, and are wearing a long sleeve shirt or sweatshirt, the cuff pulls open the ashtray flip cover.) I'd also like to see someone address the cup holder in the upper console - totally useless, and ugly. I'd like to see someone be able to fill these in - keeping the same shape of the OE console, then cover it in leather. I think that would change the whole appearance of the console.
SLPHawk300 is offline   Reply With Quote
Old 12-21-2010, 02:59 AM   #56
KLaBZ28's Avatar
If I can get my hands on an LT1 camaro radio bezel and spare LS1 console and a shitloat of time I'll attempt molding an ls1 console to the radio bezel lollol.
Old 12-21-2010, 03:05 AM   #57
FactoryPhil's Avatar
that photochop pic looks great, your progress is coming along
FactoryPhil is offline   Reply With Quote
Old 12-21-2010, 03:32 PM   #58
PERFECT Z28's Avatar
Keep us posted!
PERFECT Z28 is offline   Reply With Quote
Old 04-15-2011, 01:59 PM   #59
Copy & Paste Moderator
VIP1's Avatar
Any Update?
VIP1 is offline   Reply With Quote
Old 04-16-2011, 11:55 AM   #60
LT4vert's Avatar
Its still alive and well....I am just( and have been)absolutely buried in school projects right now and a full time job I hope to get back at this early this summer, along with some cool 98-02 camaro dash stuff too.
Related Topics
Thread Thread Starter Forum Replies Last Post
New grill design for Camaro LT4vert Appearance & Detailing 95 05-23-2015 04:41 PM
ZR1 type gFX part 2 . LT4vert Appearance & Detailing 23 01-06-2011 12:50 PM
Messing around with a new material I found . Dry carbon wrap vinyl . LT4vert Appearance & Detailing 21 09-29-2009 01:36 AM
Various colors of GM's released frontal pic , headlights too . LT4vert Gen 5 Racing Tech 38 03-13-2008 02:21 AM
Tags
9802, alcantara, bondo, camaro, center, console, dynatron, large, ls1, mould, projects, sealers, trans, transam, wrap, wrapping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
